Results 1 to 3 of 3
Thread: NuXT - MicroATX Turbo XT Motherboard Add: Glitchworks XTIDE
    Default NuXT - MicroATX Turbo XT Motherboard Add: Glitchworks XTIDE
    I'm not clear on how to get the Glitchworks XT-IDE REV 4 to co-exist with the CF HDD on this MB. Right now, adding the XT-IDE overrides the on-board one... I want them to co-exist but I'm having some difficulty figuring out how its done.
    Looking for guidance.
    I know nothing about the NuXT motherboard but i'd look at what Address they both use, You'll probably be better off asking the designer / seller of the NuXT motherboard as they should have intimate knowledge of the GW XTIDE and XUB and other designs.
    Jan 2010
    Central VA
    4,670
    Quote Originally Posted by Malc View Post
    He should definitely know about the rev 4 design, being as how that's what he copied for the version he sells. He took the copyright info off but it appears to be the same circuit, just rearranged.
