Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Power switch issue with my 386
    32,251
    18
    Okay, so grab your DMM and set it to continuity. See which lugs are connected with the switch "on" and then make sure that they're not connected with the switch "off". That will pair them off. Connect wires of the same color to the appropriately paired lugs. Black wires normally indicate the "hot" side of the line and white, the neutral.
    Apr 2015
    Austin, Texas
    1,645
    Quote Originally Posted by itsvince725 View Post
    I have the wires that were originally soldered to the lugs of the switch so I was just going to reuse them and add connectors to them. The only problem is, I don't remember which lugs had black wires and which ones had white. I have two black and two white wires.
    You need to take pictures of this stuff, wiring one of those switches incorrectly can lead to stuff blowing up because it's switching mains.
    If the switch has a neon lamp inside it, one pair of contacts is probably for the lamp, while the other is to complete the mains circuit for the power supply to turn on.
    Duh! Don't you believe in taking notes or at least pics?
    doesn't really matter it's an isolated DPST switch, just put both blacks on one side and both whites on the other
    Nov 2016
    Quakertown, Pennsylvania
    368
    Thanks!
  5. #15
    Quote Originally Posted by maxtherabbit View Post
    So, which is it?
    Both can't be correct.
  6. #16
    32,251
    18
    The problem is that you've got 4 terminals and it's not clear how they're paired. My method identifies the pairing.
  7. #17
    Yeah just buzz it out, takes a second and you can be sure
