Results 1 to 4 of 4
Thread: This is a test
    Default This is a test
    I joined 11 years ago but my reply posts are waiting in approval for 2 days now. So testing if I can make a new post.
    bp
    Mar 2009
    Dublin, CA USA
    2,810
    The amount of time you have an account is irrelevant. It has to do with the number of posts. Once you reach 10, then you will no longer be moderated, you are currently at 6.
    Thank you. I think I'm at 10 posts by now, having put up more IRC and BBS photos.
    Cheers.
    bp
    One last test.
    :: Byte Cellar - the vintage computing weblog
    :: http://www.bytecellar.com
