Results 1 to 7 of 7
Thread: PHP/JavaScript programming help wanted for manx
    Mar 2006
    Salt Lake City, UT, USA
    363
    Default PHP/JavaScript programming help wanted for manx
    You may know about the manx documentation database. What you may not realize is that the entire implementation of this web site is open source on github.
    I work on it when I find slices from my bucket of "copious spare time".
    After VCFMW there was some discussion of making some improvements to manx. I will eventually get to them, but it would go faster if some other people were to help out.
    The code is heavily unit tested and in the past week or so I've been modernizing the code to PHPUnit 6, which simplifies some of the testing.
    The future needs are not particularly difficult, but as I say it would go faster with some help.
    Take a look at the github repository and if you think you're up for it, let's talk about how you can help.
    Thanks!
    Mar 2006
    363
    I've been doing a bunch of work on the develop branch recently. In general, the PHP community infrastructure has advanced significantly since I started coding this application around 2010. When I started coding this, the PHP community didn't have a package manager and finding high quality libraries for writing a PHP application was difficult if you didn't work in this space on a daily basis. I've spent some time catching up to "community norms" for PHP applications and have tried to make the code base more modern and normative instead of home brew and full of NIH/DIY-isms.
    The next release will be 2.0.7, a minor release containing some bug fixes and one feature: automatic ingestion of most bitsavers docs.
    Here's an overview of work that's been done on develop for the next release:
    • Added travis-ci.org continuous integration builds that validate that the tests stay working (modernization)
    • Switched to using composer for PHP package management (modernization)
    • Updated to use PHPUnit mock objects instead of hand-crafted test doubles in the unit tests (modernization)
    • Eliminated a bunch of code and database duplication between processing of bitsavers.org and chiclassiccomp.org IndexByDate.txt files for automatic ingestion (refactoring)
    • Switched from home-brew dependency injection to using Pimple\Container (modernization)
    • Resurrected all the open issues from the old codeplex project and injected them into github (open bugs, community)
    • Fixed some small bugs that were open on codeplex (open bugs)
    • Added a wiki page that gives an overview of the code architecture (community)
    Remaining work to do:
    • I have a little bit more testing and bug fixing to do on develop (mostly around the IndexByDate processing) (refactoring)
    • Ingest changes to IndexByDate files more efficiently (performance)
    • Automatically ingest documents from IndexByDate files (feature)
    The main thing that is lacking in the application right now is editing existing data when authenticated as a logged-in user. This will be more important with automatic ingestion of bitsavers documents based on the IndexByDate.txt processing.
    I'm looking at the Slim framework to make it easier to write pages for editing data. In general, I think the way to move forward with new features is to expose REST API endpoints through Slim and then have front-end JavaScript that performs the operations via AJAX calls. Slim also has facilities for rendering pages from templates, which will make it easier for writing new pages in a sane manner. Some edit pages and corresponding endpoints will end up forming the next release, tentatively named 2.1.0.
    Mar 2006
    363
    I added a couple wiki pages describing the support for an IndexByDate.txt and inferring document metadata from document URLs.
    Mar 2006
    363
    Spent a part of the weekend doing some more hacking on this. I made good progress on automatic ingestion of documents from the IndexByDate.txt file. It's looking like 2.0.7 might release next weekend.
    Mar 2006
    363
    A basic implementation of automatic document ingestion has been created and is undergoing testing. It still needs some tweaking to identify documents whose titles begin with something that looks like a part number.
    Mar 2006
    363
    I've been testing the automatic ingestion and I need to improve the recognition of part numbers from the URLs. Because different companies use different forms of part numbers, I'm thinking of a set of regexes associated with a company and/or subdirectory to match part numbers from file names. If the pattern matches, then it's assumed to be a part number and is used for adding the document. Otherwise, I'm just getting too many bogus documents added.
    As a result, it looks like 2.0.7 won't ship this weekend, maybe next weekend. When developing heuristics like this, you just have to test repeatedly against the typical dataset so you can improve the heuristic. Due to the open-ended nature of the test/revise cycle, it's hard to say when it will be good enough to deploy, but we're getting much closer.
    Mar 2006
    363
    Work has been a little crunchy lately, so 2.0.7 is making progress, but has slipped a few weeks. It turns out that ingesting documents from bitsavers IndexByDate.txt is possible, but with lower accuracy than I would like, so will need some improving over time by building up heuristics for various directories in bitsavers. This likely means that a human will curate a pattern for a directory allowing all the docs in that directory to be ingested, instead of curating the ingestion of each individual document.
    I'm going to keep the limited ingestion I have now as part of 2.0.7, fix the remaining open issues for the 2.0.7 milestone and then work on improving the automatic ingestion for 2.1.0.
