Results 1 to 3 of 3
Thread: IBM 6580 Displaywriter not booting correct
    Default IBM 6580 Displaywriter not booting correct
    Hello,
    is stop at
    *801* 03 03 and LED behind show F G H
    press then the Memory Record Button
    *801* 05 03 05 LED E
    *801* .D L no LED
    * 11* IBM Logo
    AC Motor from Disk Unit runing but not reading any disk.
    can some help ?
    thx
    6,920
    At [here] is a lot of Displaywriter documentation.
    One of the documents there is named S241-6248-3_Displaywriter_Product_Support_Manual_Feb83.pdf, and its chapter 9 covers diagnostics.
    Have you seen that?
    For example, page 9-6 (PDF page 198) suggests that the first error that you see is a failure of the DMA controller test.
    Have you tried re-seating all cards in the system unit?
    Thank you yes i have re seating all cards. How can i check a dma controller ?
