Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 68
Thread: FPGA accelerator cards
  1. #21
    (*Edit: Seriously, now I want to see someone put a small SBC equipped with CPU that has modern VT/IOMMU extensions into an ISA slot/8088 CPU socket. Then use hypervisor mechanisms to allow a DOS session running on the card to directly access the hardware in the parent machine. Just think of all the wait states...)
    I remember having a conversation with a coworker once about the fact that we now have CPUs with L1 cache larger than the entire main memory of even some low-end 386 setups. It'd be amusing to try rigging up the minimum possible translation layer required to run a virtual-8086 session on a modern PC motherboard and see how fast it could be pushed with the entire affair running out of cache.
  2. #22
    Dec 2008
    United States of America
    100
    Don't some modern CPUs actually drop support for 8088 and similar?
  3. #23
    32,550
    Depends on what you mean by modern. The recently-discontinued Itanium IA-64 series has its own instruction set, not compatible with x86.
  4. #24
    Outer Mongolia
    1,588
    Modern x86 CPUs combined with 64 bit EFI no longer do much initialization in Real Mode, but they do technically still have it. And even though vm86 mode no longer exists in 64 bit mode you can still access *that* by using a hypervisor running the chip in 32 bit mode. (VT-x is helpful.)
  5. #25
    Jan 2005
    Principality of Xeon (NJ)
    1,370
    Meaning they were manufacturing them until recently?
  6. #26
    32,550
    Intel announced discontinuation this year. They're history.
  7. #27
    Jan 2005
    1,370
    Zounds. I thought they were already ancient history.
  8. #28
    32,550
    Gone, pretty much
    I thought they were already history when AMD64 came out. Amazing how long they've held on.
    So, that leaves us with current production of what, x86 and ARM for CPUs? (I'm not counting MCUs, which are far more varied).
  9. #29
    Sep 2006
    Silicon Valley
    2,023
    that's pretty much it in 'PC' space
    MIPS in SOCs, SPARC, and POWER in Fujitsu and IBM
  10. #30
    32,550
    I thought that IBM was dropping POWER from development.
