Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 94
Thread: Anyone good with logic gates and BJT Transistors??
  1. #21
    Jun 2012
    UK - Worcester
    4,121
    I have also had a look at the two matrix organisations for the two keypad and I don't think you can use a simple lookup table in the form of an EPROM, PLD etc.
    If using a micro controller you will also have to ascertain the scan frequency of the control board and ensure that your interface solution can work well within this. You will also have to "roll your own" keypad de-bounce logic etc.
    Not sure in the US what the prevailing Standards and Regulations would be for elecromagnetic susceptibility etc. What you don't want to happen is for everything to work OK in your office and then to fail when you install it in a factory or when someone decides to use their mobile phone when purchasing a drink (or whatever your vending machines dispense).
    You will also have to consider using the watchdog timer just in case the micro controller crashes. If it doesn't recover, presumably your vending machine is useless!
    Dec 2005
    Toronto ON Canada
    7,373
    Quote Originally Posted by daver2 View Post
    Why not? Unless I'm missing something the old keyboard can generate part of the 12-bit address and the 'new' scan lines the rest, and one of four output bits goes to the 'input' (this assumes the left numbers are the scan lines).
    No?
  3. #23
    MikeS: A simple PLD solution *MIGHT* be possible but first one needs to know which of the output keypad lines generate the scans and which are detectors. After that you can check whether they can be used for scan lines on a "naked" input keypad with PLD translation.
    A potential problem with a microcontroller solution is the two or three clock domains. Either performing it's own scan or tapping into existing input scan logic is fairly straightforward so long as it retains the current scan status. However, unless it uses twelve relay-style outputs there is a potential problem. Detecting the output-side scan and generating a response is fairly straightforward *BUT* there will be a delay. Unless the downstream circuit is carefully checked, there remains a question of where during the scan interval a "closure" detected. Early detection during the delay period creates a major problem.
    Assuming TTL-level inputs and outputs, I still believe a single PLD (possibly CPLD) device can perform a reliable low-cost translation. A "naked" input keypad could us the output scan lines as it's input multiplex triggers.
    The PLD would have twelve SR flip-flops holding the last scanned state of the input keys which can then be used to generate immediate responses to the output scan requests. Each flip-flop is SET on multiplex+closure and RESET on multiplex+open. This way they retain the last scanned input value. Appropriate outputs (likely open-drain) are generated based on the output scan signals. Debounce logic should already be incorporated into the existing output circuit.
  4. #24
    Jun 2012
    UK - Worcester
    4,121
    MikeS,
    Have you got a concept sketch for your proposal?
    I think I may have chosen the other set of numbers for the scan lines...
    Dec 2005
    Toronto ON Canada
    7,373
    [QUOTE=WSM;590241]MikeS: A simple PLD solution *MIGHT* be possible but first one needs to know which of the output keypad lines generate the scans and which are detectors. [quote]
    Absolutely; we need to at least know which is which and the voltage levels involved.
    Sounds like we're on the same track, although the EPROM wouldn't (need to?) latch the keypress values.
    Either way, I think it would be trivial to implement on a cheap single chip once you've worked out the truth table, without having to worry about clock synchronization, spurious resets, etc.
    But it would be interesting to implement on a BASIC Stamp with relays etc.; definitely more "fun"...
  6. #26
    35,383
    18
    And now you understand what I posted what I did about getting details before offering suggestions.
    Been caught in that trap before--it gets embarrassing and expensive.
  7. #27
    But you can walk out! ��
  8. #28
    35,383
    18
    No, I specifically requested more information. Scan patterns, voltage polarities, etc. would be useful.
    I try not to go into things blindly. You're welcome to, however.
  9. #29
    No suspicious minds round here today...
  10. #30
    I was when I did engineering in electronics back in 2013 :P
