Results 1 to 10 of 12
Thread: WTB: Intel Inboard 386 AT card
    Default WTB: Intel Inboard 386 AT card
    If someone sell it for normal price, PM me.
    I have also US address.
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155: IBM PC Expansion Unit 5161:
    WANTED!: IBM 5175 monitor, IBM 5145 monitor, IBM PC rear screws, IBM Type13/WD 25 Hard Drive front panel/mask, Intel INBOARD 386AT card, IBM 5140 keyboard.
    My IBM PC hardware collection
    Mar 2009
    Dublin, CA USA
    2,799
    Quote Originally Posted by romanon View Post
    I am curious, what do you consider a "normal price"?
    I dont know, about 100$
    Jan 2005
    Principality of Xeon (NJ)
    1,349
    Now I want one too.
    Is this basically a bog standard accelerator like early Orchid units? Or is a 2nd functional computer within the box?
    Now I want one too.
    Neither
    It’s a socketed 386 with ram on an ISA card with a ribbon cable to the 8088 socket.
    To run it’s best you need it’s drivers and a special version of Windows 3
    Feb 2006
    Jacksonville, Florida
    1,260
    Quote Originally Posted by rmay635703 View Post
    Neither
    There are 2 versions of the board. The Inboard AT replaces the 80286 processor and is a 16 bit board. The PC/XT version is the one you are referring to.
    http://www.cpushack.com/2019/08/14/h...nboard-386-at/
    The Inboard AT requires a special cable from the 386 board to the 80286 socket. That cable is virtually unobtainable.
    Dec 2010
    Seattle, WA
    1,843
    Jan 2005
    1,349
    Some bozo is likely to bid eventually. That's on them not me.
    Jun 2013
    Montevideo, Uruguay
    391
    499 ?, too cheap.
    Get this one boxed ! mint ! like new ! 999.95 this offer is only available as a promotion ! don't miss it !
    https://www.ebay.com/itm/NEW-SEALED-...oAAOSw3ehdn7sg
    Ha! I saw it...I am not fool.
