Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Copy II PC Formats
    Sep 2016
    Shrewsbury, MA
    1,048
    Default Copy II PC Formats
    I just got my 5160 set up with a Central Point Deluxe Option Board and I was just wondering what format of disk image Copy II PC needs. Specifically I have a copy of King's Quest for the PCjr as a .img file and I want to write it using Copy II PC.
    .IMG files are not copy protected and neither need nor use Copy II PC. Try a normal .IMG program like Winimage or Rawrite.
    Sep 2016
    Shrewsbury, MA
    1,048
    The problem is King's Quest is not in a regular format so neither of those work. I've tried everything I can think of to try and write it and nothing works. Even Copy II PC glitches out when I try to write a disk.. Maybe someone can post an image they made with Copy II PC so I know it'll work?
    Where did you get that file?
    32,706
    18
    CopyIIPC files are sui generis; as far as I am aware, there exist no format interchange utilities for those.
    Jan 2013
    Marietta, GA
    3,305
    The software used by a Central Point Deluxe Option Board is "Transcopy".
    "Copy II PC" is the copy utility that needs no extra hardware.
    Transcopy uses the extension ".IMG" by default, but it is not a sector image. Everyone who uses Transcopy renames the files to the extension ".TC" for distribution. (And then renames them back to .IMG unless they modify their TC.EXE to look for the .TC extension instead).
    32,706
    18
    I thought that the OP said that he had a DOB already. I assumed that he also had the software.
    Sep 2016
    Shrewsbury, MA
    1,048
    I do have the option board and original software. I think I just got copy II PC mixed up with Transcopy, that's what I'm using to try and write these images. The image files are from the Total DOS Collection
  9. #9
    Quote Originally Posted by RadRacer203 View Post
    Once again...
    Quote Originally Posted by SomeGuy View Post
  10. #10
    Sep 2016
    Shrewsbury, MA
    1,048
    The issue is I've tried pretty much every program I can find including winimage and rawrite and I still can't make a working King's Quest disk. I'm certain that I can make one with this setup but I can't get Transcopy to write the disk. It glitches out and freezes when I try to write it
