Results 1 to 9 of 9
Thread: Cheat on driving long OC loads?
    32,489
    Default Cheat on driving long OC loads?
    I'm working on a design that involves driving 5V 220/330 ohm terminated lines, TTL levels. The spec calls for OC drivers, but I'm wondering if I can get away with driving 1-2 m lines at about 1.4 MHz using a 74HCT244 totem-pole output ather than the more expensive 74HCT760. Same pinout, so I could swap the ICs if one didn't work well enough.
    Any advice--is it worth trying?
    Mar 2013
    Chaffee, MO
    1,209
    Chuck,
    Google isn't locating the 74HCT760 Datasheet for me. Was there a typo?
    If you have the 74HCT760 Datasheet will you upload it?
    Thanks.
    Larry
    Mar 2017
    New Jersey, USA
    503
    I don't see any reason not to give it a try. A 1.4MHz signal has a wavelength of 214 meters, and your lines are a tiny fraction of that. As long as the capacitance of your lines is small I'd guess you'll have no issues, but AC signal transmission is *way* outside my zone, so much so I considered not replying at all.
    Also 1.4MHz is a 714ns period (assuming I didn't lose track of the decimal point) or 357ns for a half-period, so the enable/disable/transition times for the 74HCT244 look like they will easily handle that.
    Anyway, as long as you can manage line capacitance to prevent instantaneous output current from exceeding 35mA I don't see why using this part would cause any problems. And since it's easily swapped, why not?
    Sep 2006
    Silicon Valley
    2,018
    Quote Originally Posted by kgober View Post
    The issue is actively driving the line when it is high, instead of letting it be pulled up to 2/3 vcc by the terminator network.
    I assume it would be used on a unidirectional signal line?
    Sep 2006
    Silicon Valley
    2,018
    The only thing I can think of that might be a problem is if the device you are talking to isn't powered on.
    We burned up a ribbon cable once where the device being driven was off, and the cmos interface drivers
    tried to supply power through the terminated signal lines.
    32,489
    Chuck,
    Sloppy fingers--it's the 74BCT760
    32,489
    Unidirectional--as I said, terminated through 220/330 ohms on the far end, which uses bog-standard LSTTL as receivers.
    Feb 2011
    2,241
    10
    If you use OC drivers do you terminate at both ends?
    G4UGM
    32,489
    No, just the far end.
