Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Tandy 1000 TL that eats power supplies
    May 2011
    Outer Mongolia
    3,061
    From the looks of that board it might not be a bad idea to just clean it at the same time you replace the '244. It looks pretty dirty, it's possible there could be something sticking to it that's messing with you.
    Jul 2009
    Central Florida
    3,786
    Great Idea @eudimorph to clean up the board cause it looks like a light layer of rust?? Which in theory could act like a semi conductor. I usually use ISO alcohol but that is just me.
    *FrankG*
    The electrolyte used in capacitors is a base. Use white vinegar and then rinse with water, followed by DI water rinse.
    Dwight
    Jan 2011
    Vancouver, BC
    5,061
    3
    It seems to be mostly just thick dust and grime... maybe from being stored in a shed. I wonder if I should do the dishwasher trick?
  5. #15
    May 2011
    Outer Mongolia
    3,061
    Shed dirt may well have a lot of rust and other potentially conductive yuck in it, any kind of bath is probably not a bad idea. I usually use a combination of alcohol and vinegar treatments with some light toothbrush-ing, but as long as whatever you use isn't corrosive and you're careful to make sure the board is bone dry before you try applying power to it again the exact method is probably not that critical.
  6. #16
    Don't put switches in the dish washer.
    Dwight
