Results 1 to 3 of 3
Thread: Making Model 1 spacers
  1. Default Making Model 1 spacers
    I've had some success making new Model 1 spacers and thought I'd pass along what I did.
    For background, back in the late 80's you could easily find Model 1s for cheap or free so I collected a lifetime supply of spare parts and systems. They got boxed up and have been in my garage for the last couple of decades. I've got 8 keyboard units plus a bare "parts" motherboard, 4 expansion interfaces, three monitors and a bunch of peripherals (including 2 voice synths). My plan is to bring them back to working condition and then unload all but 2 full systems. I've got most of the keyboard units working again, but need lots of spacers to replace the missing and crumbled ones.
    Because I have a cheap hobby mini-lathe I thought I'd just manufacture some new nylon spacers. It's working pretty well. I got 1/2" nylon rod stock from Online Metals (https://www.onlinemetals.com/en/buy/...tural/pid/6665), popped it in the lathe, drilled out with a "Q" size bit and parted off by eye using an old spacer as a guide. I'd never cut nylon before, but it worked OK. I think slower speeds worked better and this was the first time I'd used the Q drill bit so it was sharp. I didn't use any cutting fluid and so long as I only drilled a couple of inches at a time I had no problems with heat. Biggest time sink was getting rid of the nylon bur.
    A single 1' rod yielded 24 spacers.
    Here's what it looks like:
    (or https://photos.app.goo.gl/F9Uhk1DHUKaD68xcA if that didn't work)
    ...Bill
    32,523
    18
    Good for you--but are you certain that these aren't stock parts?
    Jun 2015
    Sioux Falls SD
    333
    Interesting. You might also see how others address this:
    http://www.vcfed.org/forum/showthrea...-model-1-units
