Results 1 to 2 of 2
Thread: Heath 286 laptop
    Default Heath 286 laptop
    I have a chance to get a Heath 286 laptop. It has to power brick so testing is going to be difficult. Does anyone know the power brick's specs? amps, volts, plug size? Any info would be helpful.
    4,841
    Do you know what model Zenith laptop it is? The bulk of the Heath PC compatibles were better documented as their Zenith counterpart. Many Zenith laptops have a label indicating the power requirements so trust that.
    An old thread http://www.vcfed.org/forum/showthrea...e-Power-Supply quotes a Radio Shack guide to replacing laptop power supply which might be helpful.
