Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Compaq LTE Lite Floppy Belts
    2mm is a pretty common belt width. Have you considered looking in a kit like this?
    I bought a similar kit (actually it might be the same one, but came off Amazon rather than eBay) to fix my Zeos floppy drive.
    There was a belt in there that worked, but I had to stretch it first (left it around a bottle that was slightly larger than the belt diameter for a week or so) because it was a little too tight to allow the motor to get going.
    I have a similar issue with portable 3.5" FDDs for my vintage Toshiba Tecra 510/730 laptops. Motors spin, but not enough belt friction to spin a disk. Bought the kit and will see what happens!
    Thanks again, Chuck!
    “The Bex religious impulse does have its collective side. As in, collect everything and hold on to it whether you remember where it came from or not.”
    —Alberto Fossa, Privateer 2
