Results 1 to 10 of 12
Thread: Compaq LTE Lite Floppy Belts
    5,781
    44
    Default Compaq LTE Lite Floppy Belts
    I was having issues with a new 4/25 I purchased and suspected that it was using a belt driven floppy drive.
    Sure enough, the Citizen V1DA-15A uses a belt and said belt has given up.
    Does anyone know of an AFFORDABLE source for replacements?
    = Excellent space heater
    32,479
    What's the circumference of the belt? I wonder if the replacement belts sold for the Amstrad CF2 drives will work--they're still available.
    32,479
    You could also have someone 3D print one for you. Here's the info for the Amstrad belt:
    https://www.thingiverse.com/thing:2854841
    Sep 2003
    Ohio/USA
    7,682
    I have that Citizen drive in a Compaq, still looking for a belt.
    5,781
    44
    I could not even tell you much about the spec of the old belt. Looks like the motor started after it perished and it wrapped itself around the motor spindle until the assembly jammed.
    32,479
    Clean things up, take a bit of twine or thread and loop it around both pulleys, cut and measure what you've got. Deduct a few mm for stretching and Bob's your uncle.
    5,781
    44
    Total loop length: 230mm
    Belt width: 2mm
    Belt thickness: 0.5mm
    Sep 2003
    Ohio/USA
    7,682
    Belt width: 2mm
    Did you find a match anywhere?
    5,781
    44
    No.
    AFter the amount of hair pulling it took to disassemble the drive and get the damn string to stay in place to get the measurement I put the system back together and started drinking heavily.
    32,479
    2mm is a pretty common belt width. Have you considered looking in a kit like this?
