Page 19 of 20 FirstFirst ... 9151617181920 LastLast
Results 181 to 190 of 199
Thread: Unique S-100 computer (Z-80/Vector Graphic/Micropolis)
  1. #181
    Dec 2005
    Toronto ON Canada
    7,349
    Quote Originally Posted by deramp5113 View Post
    You can pick out the pattern even with an incandescent bulb. Not as obvious as fluorescent, but it’s there.
    Mike
    True enough, but incandescents are getting as hard to find as 'real' fluorescents and certainly not nearly as clear. But if that's all you've got...
    BTW, Mike, let me take this opportunity to thank you for your many contributions to the hobby!
    m
  2. #182
    LOL I did do this with a real fluorescent fixture - I had one for plants/seed starting - not CFL or LED. I swear I can't make out any pattern at all.
  3. #183
    We can rough check timing with a scope. Measure sector to sector time by monitoring test point 3, negative edge triggered. Note you’ll have a half-sector time slip in periodically at the index pulse. What interval do you measure?
  4. #184
    Dec 2005
    Toronto ON Canada
    7,349
    Quote Originally Posted by nullvalue View Post
    Well, there is the possibility that the speed is too far off; time to check it the hard way as Mike suggests
  5. #185
    I'm not sure I have my scope set up to capture this correctly, maybe you can make sense of this? I've recorded what TP3 looks like during the boot loop. Volts/Div is set to 1V, Time/Div is 2ms.
    https://www.youtube.com/watch?v=Q72uuYmHDow
  6. #186
    The flicker is the full rotation index pulse at 1/2 the sector time that you have to ignore. Looks to me like that drive is about 5.2 divisions or 10.4ms. That’s way too quick, nominal is 12.5ms (300 rpm, 16 sectors). See if you can adjust R89 enough to get the drive to 12.5ms (6.25 divisions). Then you should be able to see the strobe pattern and do final adjustments.
    Mike
  7. #187
    Thank you, that helped me get it dialed in! I couldn't see a pattern at all, frustrated I tried under my normal LED bulb lighting and behold, a spinning pattern! I adjusted until the pattern holds steady, as can be seen in this video:
    The outer pattern holds still (that's what we wanted, right?)
    https://www.youtube.com/watch?v=kt9ZcF1eL2U
    However, I went through the whole disk creation process now - twice - and same results as before. Disk writes successfully, but then (B)oot just sits there spinning the disk. It finds track 0 but then just spins.
  8. #188
    See what the boot ROM checksum is. Type "Q F800 F8FF"
    Mike
  9. #189
    Yep already tried that.. it's "BC"
  10. #190
    Well damn, yep, that’s correct. Post pictures of the Micropolis controller board mods. If the motor mod is done (that one stops the motor about four seconds after the drive is deselected), but the “ready mod” is not done, CP/M disks don’t work. Did you ever try the “ CPM22A-MikeD.VGI” disk images instead?
    Mike
