Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: ISA Novell network card - I can't for the life of mine determine it.
    Jan 2005
    1,512
    I don't own the card. Just saw a listing on ebay.
    33,093
    Almost certainly a serial network card (<3 Mbps). Recall that early Novell cards used RS422 serial.
    No setup disk, it's a jumper-type card, not PnP/jumperless. The usual NE2000 drivers should all work fine. If this isn't an actual Novell/Eagle card it's just someone else running their layout (iirc the design was basically open source). The board/assembly number on the top edge will tell you which revision, I believe the two most popular ones are on TH99. You can find a webified version from stason.org.
    OK, do you know where one could find the manual or at least the jumper settings for this card?
    Feb 2012
    New Zealand
    2,643
    Quote Originally Posted by Sir_Fartalot View Post
    I googled "NE2000 jumpers" and the first link was this: https://support.microfocus.com/kb/doc.php?id=1200390
    But probably what you want is actually this: https://stason.org/TULARC/pc/network...0-149-00X.html
    That should contain everything you need to know.
    Yours seems to be set to 0x300 address, and IRQ 5, which is pretty normal.
    I tend to prefer IRQ2 (which gets redirected to IRQ9), because IRQ5 often gets used either by sound cards (I set mine to 5, so I can keep 7 for printing) or XT hard drive controllers (if used)
    Quote Originally Posted by SpidersWeb View Post
    That's very excellent! Thank you, sir.
