Results 1 to 10 of 17
Thread: Open source flux reader/writer running on $2 bluepill board
    Default Open source flux reader/writer running on $2 bluepill board
    I'm sure a fair few are aware of FlashFloppy, the open source firmware for the gotek floppy emulator. Its creator Kier Fraser has pushed out Greaseweazle, which is a flux reader/writer running g on the super-cheap bluepill stm32 board!
    It reads/writes supercard pro format files at the moment, but you can use things like the open source HxC floppy emulator software to bodge that into other formats.
    Available here: https://github.com/keirf/Greaseweazle/wiki
    Two bucks vs 100 for a scp or even more for a kryoflux
    d.
    32,682
    What I've been saying for years--most any inexpensive capable MCU can do the work of a kyroflux.
    I use the STM32F407 boards for a lot of things--only about $10 and that includes a fast CPU (with floating point, 192K of SRAM, and 40-some 5V-tolerant GPIOs), battery-backed RTC, external flash, LCD interface and a header for a WiFi module.
    Aye. They are really impressively featured uCs. It just took someone getting around to doing it. There is now a complete open source archive->emulation chain, with consequently really excellent support.
    32,682
    Years ago, I posted about using an AVR ATMega256 as a kyrofluxish project--and as an emulator. It required an external 128KB SRAM, but otherwise worked well. Couldn't get any interest going; mostly because the ATMega256 was a QFP and people weren't very receptive to building their projects using SMT. I did a through-hole version using an ATMega162, but it actually cost more than the ATMega256 one. Flash was full-sized SD card.
    What the world was waiting for was a complete capable cheap MCU on a board.
    Aug 2009
    Oslo, Norway
    1,278
    3
    Interesting - I must follow this and see if it evolves.
    Torfinn
    32,682
    I've already programmed the BP with the firmware and will get the connector wired up and give it a try this week. I opted to buffer the outputs through a 74LS244 and add 2K pullups to the inputs just so there would be no problems with older 5.25" drives. Needless to say, I've altered the program code a bit (e.g. changing the open-drain output configuration to push-pull). I used an ST-Link programmer rather than the serial bootloader option--just preference on my part; I'm already set up to use OpenOCD and the ST-Link for my other STM32 devices.
    It's interesting in that the firmware code doesn't use any of the standard STM32 libraries (HAL, libopencm3, SPL, etc.). It's pretty much self-contained.
    Sep 2006
    Silicon Valley
    2,041
    Quote Originally Posted by drdanj View Post
    and it looks like the fluxengine guy is about to abandon what he's been doing
    https://github.com/keirf/Greaseweazle/issues/3
    the re-invention wheel keeps-a-spinnin'
    Aug 2009
    Oslo, Norway
    1,278
    3
    Abandon? No. But he has long been looking for cheaper hardware (or hw that don't require closed tools) https://github.com/davidgiven/fluxengine/issues/5
    up to now, he didn't think that the blue pill was powerful enough. We'll see what happens
    Torfinn
    32,682
    Well, I do the same with a STM32F407 board (about $10), which is quite a bit more capable, but the BP has me interested in minimalist imprlementations.
    I think it's because he's making the entire thing PD - if you used the HAL you'd be GPL'd?
    I programmed initially with the STLINK, but have been using the self-update now, which is quick and easy. I've stuck 1k pullups on the inputs, but it seems to behave perfectly well with my 1.2MB PC 5.25" drive - I've not tried it with anything truly ancient
