Results 1 to 8 of 8
Thread: Sol-20 light pen project
    Default Sol-20 light pen project
    I have just completed my light pen project for the SOL-20. The article describing the Hardware and the Software is here:
    http://worldphaco.com/uploads/LIGHTPEN.pdf
    A short video is here:
    https://www.youtube.com/watch?v=awPFZCJFguM
    As noted in the article, there were some interesting technical challenges. The article also details the design and explains the circuitry. I had never tried a light pen until doing this project, it was a lot of fun designing the hardware with the software control in mind and the notion of what is better done in hardware vs software.
    32,716
    Interesting, Hugo! The light pens that I recall of yore had a switch activated by pressure on the pen tip. Clearly, these were made for selection and not drawing. It's worth noting that several LSI controller chips, such as the Moto 6845 and Intel 8275 already have light pen capture circuitry on them. Depending on the phosphor used, it's approximate at best.
    I've wondered if a flying spot "locator" could be simulated on a modern LCD display.
    Does anyone remember the touch-screen project that Steve Ciarcia (I think it was him) rolled out back in the CP/M days? Basically a rectangular frame with LEDs on one side and phototransistors on the other. Your finger interrupted an X- and a Y-axis beam that would indicate your choice. I think the resolution was only about 8x8, but was sufficient for a "pick one" functionality.
    Feb 2006
    in the basement
    888
    I have just completed my light pen project for the SOL-20. .....
    Brilliant work Hugo...
    How many man-hours did it take from start, research, design, build, troubleshooting, and .....finish...
    ziloo
    This particular pen is an interesting one. The buttons on it do not physically move, it detects the presence of the finger with a light touch. Also, in front of the photo-transistor, there is an objective lens, so a pixel gets focused when its a couple of inches from the screen surface. I think its a good idea because it doesn't have a chance to mark the CRT's faceplate. It has a resolution of one pixel.
    ziloo
    I didn't count it up but on and off over about 3 months at weekends etc doing a little here and there making the card. Most of the time for me was figuring out the software side of it.
    4,706
    Dec 2011
    Dallas, TX
    254
    Feb 2006
    in the basement
    888
    It gets even more impressive:
    http://www.eyespecialists.com.au/hugoholden.html
    ziloo
