Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Help identifying a resistor please.
    Mar 2007
    Leicester, UK
    212
    Default Help identifying a resistor please.
    Hi Folks,
    In this recent thread I mentioned this I'd got a Canadian PDP-8 clone.
    I am in the process of restoring it and have checked out the power supplies and given the boards that make up the CPU and clean and visual check.
    I have now moved on to the core memory boards and have run across a snag I hope someone can help me with.
    Inspecting on of the two core memory boards I noticed a broken resistor on the board.
    In the hope of finding out what value it is I turned to the other identical core memory board and it has the same fault on the same resistor. Talk about identical.
    So here's is my problem. How do I identify this resistor? I have a photo but I can't see a tolerance band so I'm not sure which way to read it. Could it really be a 50 Ohm resistor?
    Can someone suggest a way forward?
    Thanks,
    Andy.
    3,466
    It looks like the next door resistor has the same band structure.
    If it was me, I would use a multimeter first to measure the resistance of an intact device and see where that takes you. Measure twice, with the multimeter probes one way them the other.
    It is either a very high value or a very low one!
    Green, brown, brown = 510 Ohms.
    Brown, brown, green = 1,100,000 Ohms = 1.1 MOhm.
    I completely agree with Dave. It looks like a 510 ohms one, but I'd not take chances and just measure the twin one.
    Frank
    I vote for 510 Ω.
    33,379
    My vote is for 510 ohm, 5%, carbon comp. A way to verify is to ascertain its function in the circuit, of course.
    I have never seen green used as a tolerance band on a carbon comp resistor. It looks like a 510 ohm to me but I can't tell if it is a brown or a faded red.
    Both boards likely failed because of the thermal stress. It is likely on a 12v rail. That would be a little over 1/4w for a 510 ohm. The resistor is only a 1/4w resistor.
    Anyway 510 is a standard value and 522 is not so I'd say within 99%, it is 510 ohms.
    I don't recommend replacing it with another carbon composition. They are poor resistors and drift a lot when run near their rated wattage. They do have low inductance compared with carbon film but then your not running at 1 GHz either. If you are an exact type freak, then use a carbon comp.
    33,379
    "If you are an exact type freak, then use a carbon comp."
    That's why I mentioned the fact that it was composition. I suspect that there are still people on this forum looking for vintage Rifa line filter caps as well.
    I note that the 68 ohm resistor to the left of the intact 510 ohm is a film resistor, so it's a big shrug. This must be a piece of industrial kit--given the Teflon sleeving and washers on each resistor. You wouldn't find this in consumer electronics.
    I might still have some. IIRC though it wasn't depicting 0.5%, it had some other significance.
    But on no three band resistor should one be tolerance, I think.
    No, no tolerance band means 20% or 15% as I recall. Silver means 10% and gold means 5%. I don't recall ever seeing a 1% carbon comp let alone a 0.5%.
    Mar 2007
    Leicester, UK
    212
    Thank you everyone for your replies.
    I read its companion both ways round and it is indeed 510 Ohms (minus a smidge) so I have replaced it with a new one.
    Looking at the size or the original compared to the 1/4w replacement, I wonder if it was 1/8w. anyway, it's gone now!
    Thanks again all,
    Andy.
