Results 1 to 10 of 10
Thread: Utility to convert intel hex into ascii stream for sending from terminal emulator
    Default Utility to convert intel hex into ascii stream for sending from terminal emulator
    I often have the need to simulate a paper tape reader and send ascii from a terminal to some hardware using “send file” as if typing (in hex or octal). For example, send code to a little boot loader or resident monitor or data to an eprom programmer
    Before I start yet another project, does anyone have a utility that:
    Reads an intel hex file
    Extracts data only from the data field
    Parses out the two digit ascii hex, optionally converting to three digit ascii octal
    Writes output as a space delimited ascii stream of the data
    Ideally breaks the output into multiple files of a target size or at original address breaks
    I am sure something close to this must already exist but I can’t find it online from the usual suspects
    Thanks
    Craig
    Dec 2005
    Toronto ON Canada
    7,240
    Don't know if this'll do exactly what you want but might be worth a look; lots of options.
    http://srecord.sourceforge.net/
    If you had Win32Forth on you machine I could write the code in about 20 to 30 minutes. I have similar code that read Hex files an writes out a binary file. It wouldn't that a lot to modify it to write out octal ascii.
    Dwight
    Quote Originally Posted by MikeS View Post
    Lots of options indeed, I did not see octal but maybe some good ideas. Thanks
    Dwight
    Thanks Dwight. But if something doesn’t crop up I’ll do it in C
    Craig
    Feb 2017
    Guildford, U.K.
    289
    Quote Originally Posted by candrews View Post
    Thanks
    Craig
    You could use a device programmer's utility to read in the Hex file and write it out as a Bin file, that ought to make it easier to separate out for creation of a stream. But I'm not sure that's what you're after.
    I use a Needhams EMP-10 with this software:
    http://ps-2.kev009.com/ohlandl/Needh...rogrammer.html
    Quote Originally Posted by WBST View Post
    His application expects an octal stream, not binary or S format or Intel Hex.
    One could make a "blue pill" be a translator. It would be trivial code but would require a little circuit to take the output to 20ma loop.
    Dwight
    This could also be written in Python, which is available (free) for all sorts of platforms including for Windows and for Linux, including the Raspberry Pi. It might be useful to know what OS the OP would be wanting to run this utility on - Windows / PC assumed, but perhaps not?
  9. #9
    Apr 2011
    Brisbane, Australia
    479
    10
    Someone on Github wrote a Python module for Intel HEX files so I cobbled this together. Not tested very much at all but definately works exactly as coded
    Python 3, pip install the library as shown in the links
    # Reads an intel hex file
    # Extracts data only from the data field
    # Parses out the two digit ascii hex, optionally converting to three digit ascii octal
    # Writes output as a space delimited ascii stream of the data
    # TODO  Ideally breaks the output into multiple files of a target size or at original address breaks
    # TODO emit binary to file
    # see    https://en.wikipedia.org/wiki/Intel_HEX
    # see    https://pypi.org/project/IntelHex/
    # see    https://github.com/python-intelhex/intelhex
    import sys
    import getopt
    from intelhex import IntelHex
    def main(argv):
       inputFile = ''
       outputFile = ''
       outputFormat = '%c '        # ascii output by default
       try:
          opts, args = getopt.getopt(argv,"hi:o:",["ifile=","ofile=","octal","hexadecimal","ascii"])
       except getopt.GetoptError:
          print('hex2ascii.py [--hexadecimal,--octal, --ascii] -i <inputfile> -o <outputfile>')
          sys.exit(2)
       for opt, arg in opts:
          if opt == '-h':
             print('hex2ascii.py [--hex,--oct] -i <inputfile> -o <outputfile>')
             sys.exit()
          elif opt in ("-i", "--ifile"):
             inputFile = arg
          elif opt in ("-o", "--ofile"):
             outputFile = arg
          # Option to Write output as a space delimited ascii stream of the data
          elif opt in ("--ascii"):
          # Option to Parse out the two digit ascii hex
          elif opt in ("--hexadecimal"):
             outputFormat = '%X '
          # Optionally converting to three digit ascii octal
          elif opt in ("--octal"):
             outputFormat = '%o '
       if len(inputFile) == 0:
             return
       print('Input file is ', inputFile)
       print('output format is ', outputFormat)
       ih = IntelHex()
       ih.fromfile(inputFile, format='hex')
       if len(outputFile) > 0:
           # Writes to a file NOTE only output printable ascii TODO write binary
           f = open(outputFile, "w")
           for x in range(ih.minaddr(), ih.maxaddr()):
               if ih[x] <= 127:
                   f.write(outputFormat% (ih[x]))
               else:
                   f.write('. ')    # print dot instead for now
           f.close()
           print('Output file is ', outputFile)
       else:
           # Writes to console
               print(outputFormat% (ih[x]), end='')
           print()
    if __name__ == "__main__":
       main(sys.argv[1:])
    Running it (Intel HEX sample from Wikipedia)
    C:\Users\you\Documents\hex2ascii>cat foo.hex
    :10010000214601360121470136007EFE09D2190140
    :100110002146017E17C20001FF5F16002148011928
    :10012000194E79234623965778239EDA3F01B2CAA7
    :100130003F0156702B5E712B722B732146013421C7
    :00000001FF
    C:\Users\you\Documents\hex2ascii>python hex2ascii.py -i foo.hex
    Input file is  foo.hex
    output format is  %c
    ! F  6  ! G  6   ~ ţ          Ň   ! F  ~  Â    ˙ _    ! H    N y # F # – W x # ž Ú ?  ˛ Ę ?  V p + ^ q + r + s ! F  4
    C:\Users\you\Documents\hex2ascii>python hex2ascii.py -i foo.hex --octal
    output format is  %o
    41 106 1 66 1 41 107 1 66 0 176 376 11 322 31 1 41 106 1 176 27 302 0 1 377 137 26 0 41 110 1 31 31 116 171 43 106 43 226 127 170 43 236 332 77 1 262 312 77 1 126 160 53 136 161 53 162 53 163 41 106 1 64
    C:\Users\you\Documents\hex2ascii>python hex2ascii.py -i foo.hex --hexadecimal
    output format is  %X
    21 46 1 36 1 21 47 1 36 0 7E FE 9 D2 19 1 21 46 1 7E 17 C2 0 1 FF 5F 16 0 21 48 1 19 19 4E 79 23 46 23 96 57 78 23 9E DA 3F 1 B2 CA 3F 1 56 70 2B 5E 71 2B 72 2B 73 21 46 1 34
    C:\Users\you\Documents\hex2ascii>python hex2ascii.py -i foo.hex -o out.txt
    output format is  %c
    Output file is  out.txt
    C:\Users\you\Documents\hex2ascii>cat out.txt
    ! F  6  ! G  6   ~ .          .   ! F  ~  .    . _    ! H    N y # F # . W x # . . ?  . . ?  V p + ^ q + r + s ! F  4
  10. #10
    On a Unix/Linux machine one could do
    objcopy -I ihex -O binary file.hex file.bin && cat file.bin | od -v -b -w8 -A none
    Unfortunately, objcopy can't output to stdout, so it can't be "piped". Also od makes a new line every 8 chars (in this example, but can have -w whatever you like).
    Frank
Tags for this Thread
