Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 73
Thread: IBM 5150 saved from junkyard
  1. #41
    Isopropanol alcohol needs to be 99% if you're using it for cleaning electronics. If you use less pure, like 70%, it will leave residue.
    And I've been using the 70% drug store stuff for over thirty years. I wish someone had clued me in.
    FWIW, I'm still regularly using some of the same drives over that thirty year period -- some of which have been cleaned with that 70% stuff dozens and dozens of times without any ill effects.
    Where did you learn that it will leave a residue?
    What is the residue that it leaves?
  2. #42
    Jun 2015
    Sioux Falls SD
    388
    I've heard that same residue warning for years and years. Supposedly, there were some rubbing alcohols that had an oily impurity. I remember testing 91% isopropanol by evaporating some on a weighing pan, and saw a residue of about 1 ppm (w/w). But that was a long time ago, and within the weighing error of the balance I was using.
    I do use 91% on drive rails, but 99% on heads. A bottle lasts a long time...
    As a side note, I cleaned a DVD drive laser with IPA, then thought I'd dry it using that "air in a can" from Costco. The head did not read a disk at all. Once I cleaned it with IPA and let it dry, all was good. So I do suspect that something in that can left a residue.
  3. #43
    So dirty air can be worse than dirty alcohol.
  4. #44
    34,397
    If you use the 99+ percent stuff, it's best to dispense it into a smaller container for application. IPA is hugely hygroscopic and an open container absorbs atmospheric water quite rapidly. I prefer the azetrope (91%) as it has the lowest BP and is very cheap.
    If I clean heads, I'll use something like perc for the stubborn deposits.
  5. #45
    Feb 2017
    Chilliwack, BC, Canada
    535
    It's just from my own experience. The 70% stuff I was using was from the dollar store, so it might just be cheap swill that's the problem.
    My vintage systems: Tandy 1000 HX, Tandy 1000 RSX, Tandy 1100FD, Tandy 64K CoCo 2, Commodore VIC-20, and some random Pentium in a Hewitt Rand chassis...
  6. #46
    hello again - i ordered a head cleaner disk, thanks!
    Here is the rear of the drive in question:
    Here is the rear of the working drive (sorry it's not the best pic)
  7. #47
    Jun 2015
    Sioux Falls SD
    388
    Can you find labels with model numbers? The first photo looks like my Tandon TM-100-2. Hopefully, cleaning the drives will help.
  8. #48
    Quote Originally Posted by phonophan View Post
    I think you'll find that to be quite useful. Old floppies can tend to foul the drive's heads quite easily and it's a simple process to clean them this way. I've been doing it for around thirty years with unwavering success.
  9. #49
    Jan 2005
    1,952
    I had that exact same game (Obliterator). At some point in the game if you lept off the deck, you would fall through several screens, and then the game would lock up or return to some point, can't remember exactly. I guess it could have been programmed to do that, but I saw it as a glitch. It would be very interesting to see a youtube reinactment of what I'm talking about.
  10. #50
    Feb 2012
    New Zealand
    2,680
    100% with you there. Often when archiving old disks I also need to clean between disks.
    One trick I'll add, is for old drives with really persistent crud, putting "more than you should" isopropyl (or whatever is being used) on the cleaning disk helps.
