Results 1 to 10 of 18
Thread: ZoomFloppy / OpenCBM/ 2031LP and 8050
    Default ZoomFloppy / OpenCBM/ 2031LP and 8050
    Hey there!
    As I continue working my way through my PET gear, I've turned my attention to the 2031LP and the 8050 drives. There's definitely something up in my PET and I'm awaiting 3446 chips. In the meantime, I hooked an edge connector up to my ZoomFloppy to give it a GPIB interface.
    Does anyone have any experience using a ZoomFloppy to talk to a 2031 or an 8050? I've got the ZoomFloppy talking to cbmctrl... I've updated the firmware to the latest (v8 ). Neither drive seems to respond to a status or detect query, though both of them react to a reset... I was thinking I wired my interface backwards except that the reset works.
    Any thoughts?
    What OS are you using? And do you own a 1541 drive? I had the weird experience that under Windows 7 I was able to read and write floppies with the 1541 but things didn't work for my 8250LP. Never found out the reason.
    www.baltissen.org
    Feb 2009
    Southern California, USA
    2,705
    Quote Originally Posted by dhoelzer View Post
    I thought they got the 8050 interface working. However I have a 4040 drive and ZoomFloppy does not work with it. It seems they put very little effort into the software debug of ZoomFloppy with the IEEE-488 drives.
    Not currently, but it works fine with my internal 1571 on the 128DCR. Obviously, that's serial GPIB rather than parallel GPIB.
    I was originally working from Windows, but had to switch over to MacOS in order to compile OpenCBM from source to support the v8 zoomfloppy firmware.
    Yes, I saw that. Actually, that's why I updated to the v8 firmware over v7, which required recompiling; none of the released opencbm installs include support for it.
    Jan 2012
    Connecticut, USA
    2,302
    Hi I am jumping in this midpoint. Are you saying the zoomfloppy does NOT read/write to the 8050 floppy drive unit? I have not tried to connect my 8050 to the zoomfloppy unit yet. I did try it with my SFD-1001 which is also a commodore ieee488 floppy and could not get it to actually write a disk.
    Feb 2009
    Chattanooga, TN - USA
    858
    A long time ago I did use my zoomfloppy with my 8050 drive.
    It worked fine.
    Later,
    dabone
    I am saying that... and I'm trying to figure out if it's the drive, my wiring, or something else. . It doesn't write to my 2031LP either, but both are supported.
    Again, cbmctrl reset will trigger either drive if it's connected, but nothing else works *at all*
    I have a 2031 (not the LP version) and didn't have much luck using ZoomFloppy with it, but to be fair I didn't spend a lot of time on it.
    Since I have a good 1541, I just use that. The 2031 is fully read/write compatible with the 1541 so the disks are interchangeable.
    IMHO if it is able to communicate with one IEEE drive, it should work for all IEEE drives. I have a small project, CBM-PC, where a PC emulates more or less a CBM. It is meant to create disk images by asking the drive to send the content of every sector of the inserted disk. I need to know what type of drive is attached because the number of tracks and sectors/track can differ. But I am using the same protocol for all the drives.
    So I think you ran into the same problem I had: not being able to communicate with any IEEE drive. So far nobody found the reason or came with a solution.
    www.baltissen.org
