Results 1 to 10 of 13
Thread: Write problems with an SD card IDE hard disk emulaator and Windows 98
    Unhappy Write problems with an SD card IDE hard disk emulaator and Windows 98
    I have a Pentium 166 MHz machine, which works fine with the original IDE disk from 96', but when I run Windows 98 from the SD card IDE hard disk emulator module, I get blue screen write errors and other page faults after the first boot and for example when I try to copy files, install Office etc.... The installation of Windows 98 completes without errors.
    I tried using 16GB and 4GB cards, but it made no difference. I use DOS 6.21 to partition the drive to 2GB Fat16. I have also tried using WHATIDE.EXE software to manually set the cylinders in BIOS, also without any luck...
    Do you think a CF card emulator would behave differently?
    Mar 2009
    Dublin, CA USA
    2,972
    My initial thought on this was bad/cheap SD card. Are the ones you are using known brands or just cheap ebay no-branders?
    Personally I much prefer Compact Flash cards for my retro machines, they are basically IDE drives and with one exception I've never had any issues with this setup.
    I prefer DOMs -- the name is self explanatory.
    Mar 2009
    Dublin, CA USA
    2,972
    No it really isn't unless you know what DOM stands for, and OP may not.
    DOM = Disk-on-Module. It is basically flash storage that emulates a spinning drive. They usually are IDE and can simply plug into the IDE header. They are a VERY good option to consider for any retro machines.
    ... They are a VERY good option to consider for any retro machines.
    Not only for retro. With 128GB IDE and 512GB SATA DOMs there are even more uses well beyond the retro machines.
    35,699
    Isn't a SATA DOM usually called a SSD?
    Thank you!
    It can be but it isn't always:
    35,699
    Other than the connectors, what's the difference? Does the DOM use SLC flash?
    Look to see what level the SD supports. Many of the newer SD cards won't work with older software, regardless of the fat used.
