Results 1 to 10 of 10
Thread: 4P CRT swap
    Jul 2005
    State College, PA
    162
    Default 4P CRT swap
    My 4P currently has the white CRT. Is it possible to simply swap out the white one for a green CRT, or does the green CRT require a different sweep PCB? Are the CRTs still available?
    To the best of my knowledge, the phosphor color of the tube makes no electrical difference, although it might have a SMALL affect on brightness settings. For example, I could get green, amber, or old-timey white (actually, kind of blue) tubes for my ADM-3 terminals (I chose white). I could get green, amber, or “paper” white for my DEC VT-320’s. I changed those to white because I don’t like amber and VT-320’s were available in those colors when new. No adjustments were needed.
    My advice would be to get a mfr and part number OFF OF THE TUBE (NOT from a service manual, the suppliers changed often back then and there may be board component differences depending on supplier), then contact a CRT supplier like VDC in Tucker GA. Call, they have a terrible website but never failed me.
    Also, be careful!
    Last edited by Slob; November 14th, 2019 at 10:19 PM. Reason: Can’t spell, can’t write either
    Sep 2011
    1,012
    You can put a green CRT from a later 4P in no probs. I've done it many times
    Huh. If you were local I'd trade you for the green one in my PET.
    Jul 2005
    State College, PA
    162
    Thanks, Ian. Do you have compatible CRT part numbers?
    Mar 2016
    Pikesville, Maryland
    216
    I happen to have them available with the Yoke assembly attached .... just swap the 2 assemblies
    For more information visit my website at plaidvest.com/newsoft
    Thanks
    Jul 2005
    State College, PA
    162
    I picked up a green CRT from Jay's site, and made the swap this evening. Works great! While I was in there, I proactively replaced the large RIFA cap in the power supply.
    Before:
    During:
    After:
    Mar 2016
    216
    I'm glad it worked out for you ................
    What do you charge for those babies Jay?
    Mar 2016
    216
    Please visit my website plaidvest.com/newsoft for pricing. Shipping is additional
