Results 1 to 3 of 3
Thread: Apple IIGS Joystick Stalls Startup
    Default Apple IIGS Joystick Stalls Startup
    When I plug in an Apple II joystick to the back of my GS, it keeps getting stuck in the control panel. I tried messing with the "Slots" settings but I can't get past the control panel. Only way I can get it to boot (I use the floppy EMU) is if I disconnect the joystick--but there's so many games I want to use with it.
    Does anyone know what could be going wrong? Is there a way to tell the computer that I just plugged in a joystick?
    Maybe one of the push buttons of the joystick is stuck in pressed position, or there is a short somewhere effectively signalling a pressed button? Try the joystick with another Apple2 computer or measure its button signals.
  3. Default
    I think so, Try the joystick with another Apple2 computer or measure its button signals.
