Results 1 to 10 of 12
Thread: Bootable floppy 5" 1.2Mb
    Default Bootable floppy 5" 1.2Mb
    Hi all
    I am new to this site, and I am contacting you from Brussels.
    I was lucky to get my first computer on which I started programming 40 years ago......
    This is a PC with a Teletek Systemaster I revision II card with two floppy disks 5 "1.2Mb and a Tatung terminal.
    Unfortunately, I have no more floppy disk. (Only the Basic floppy)
    Can you help me to reuse this PC,
    or maybe a procedure to follow in order to recreate a bootable floppy disk ?
    Thank you very much for your help.
    Patrick
    4,457
    Several here have that system but they don't shown up here in some time. The one most recently on hasn't posted for about a month. I doubt I could successfully guide through the process of turning the 8" disk images out there into working 5.25" disks.
    Since there may be a delay, could you post the model numbers for the drives? The information I have shows the Teletek having 96 tpi double density drives (for an approximate capacity of 720k) not high density (1.2MB).
    Not sure how to do it but changing the topic title to include Teletek Systemaster might make it easier for those with knowledge to find it.
    32,664
    I suspect that the 1.2M drives have been fitted to replace 8" ones. An 8" bootable image should work when transferred to 5.25" HD.
    I haven't checked my collection to see if I've got the 8" sample; but I do have the DD/QD ones.
    The floppy is Ye DATA 380 1.2MB
    But if necesssary, I could buy a 720K (if it is possible)
    Thanks
    (sorry I don't know how to rename the topic)
    Patrick
    32,664
    Do you have a working "tweener" with an appropriate drive than can run ImageDisk?
    4,457
    Quote Originally Posted by SuperPat View Post
    Thanks
    Patrick
    Changing the drive won't be necessary. The source I used seems to have been wrong.
    Sorry but I have not a tweener machine.
    Just 2 ye data 1,2Mb and basic program disk.
    I find here http://www.retroarchive.org/maslin/d...m30/index.html
    and here http://www.retroarchive.org/maslin/d...tek/index.html
    some interresting files.
    Is that files imagedisk to boot my computer ?
    And how transfer these files to floppy ?
    Is it possible to do that with tweener machine or Lotharek machine ?
    32,664
    The second link has Teledisk .TD0 files, but they can be converted to ImageDisk files.
    You can write them with a 'tweener running MS-DOS.
    I don't know what a Lotharek is.
    You need second computer with a floppy and the programm 22disk. With this program you can format different types of disk formatting architectures. And the just write the files to the disk. I am using my IBM 5170 with yd380 5.25" and 3,5" Floppys. I copy the files from main pc to 3,5" USB disk drive. With this disk, i create 5,25" disk on ibm 5170.
    Jan
    Lotharek is in Poland. They make nice hardware for vintage computers, great hardware for Atari 8 bit for example. They have a disk drive emulation system. Fits to 3,5" Floppydrive mounting slot, but you cannot indert disk, it works with USB stick.
    Jan
