Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Seagate ST-4053 and IBM AT
    Default Seagate ST-4053 and IBM AT
    Hello, I tried connect my ST-4053 to IBM AT (type 3 board).
    First problem - ok this disk is not supported by IBM BIOS, its 1024/5/17 and this CHS parameters are not compatible with any type of supported disks.
    So I tried format this disk to nearest supportable type number and this is type 17 (977/5/17) - Without success. I connected it to my 386 test computer and format without any problems to type 17. Connected to IBM AT - not success.
    Where is problem? ST-4053 is MFM disk not RLL according to information on internet. Last attempt was connect IBM AT HDD controller to my 386 computer with ST-4053 and here was problem. Its worked bad and cant format to type 17.
    ST-4038 is working on my AT without any problems.
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155: IBM PC Expansion Unit 5161:
    WANTED!: IBM 5175 monitor, IBM 5145 monitor, IBM PC rear screws, IBM Type13/WD 25 Hard Drive front panel/mask, Intel INBOARD 386AT card, IBM 5140 keyboard.
    My IBM PC hardware collection
    May 2006
    Melbourne, Australia
    6,376
    Quote Originally Posted by romanon View Post
    ...IBM AT HDD controller ...
    Suggesting that the IBM AT controller and related cables/connectors are good.
    ...ST-4053 ...
    Suggesting that the ST-4053 is good.
    Where is problem?
    By "format", do you mean DOS format, or low-level format ?
    What is the error message ?
    Some machines have flat (straight-through) control cables, and some have twisted control cables. If the IBM AT and the 386 have different types of control cables, you would have to change the drive-select jumper when moving the drive between the machines. Different types of control cable ?
    The IBM AT controller may not be compatible with your 386.
    Quote Originally Posted by modem7 View Post
    Low level format of course. I use IBM AT diagnostic diskette to LVL format ST-4053 but there was error message right on start of formating. I dont remember exactly type of error right now. Also tried with SSTORE and without success.
    Yes, I am aware of it, I deal with it with changing of jumper position on disk.
    That could indicate a bad track zero or some other fatal error which would not be uncommon for a drive of that age.
    But this drive work perfectly on my 386 computer
    Try it on the 386 again.
    I tried, disk is fine. Its not working with IBM AT controller, I dont know why..
    May 2006
    6,376
    If you run SpeedStor's seek test (via [Diagnostics][SeekTest]), do you hear the heads move ?
  9. #9
    No, seek test not passes at all, instant error in first two entries
  10. #10
    But the ST-4038 runs OK with that IBM AT controller, right?
