Results 1 to 8 of 8
Thread: Looking for MS-DOS 5, 5.25" 360KB, Disk 3
    Default Looking for MS-DOS 5, 5.25" 360KB, Disk 3
    My image is corrupted; something happened to sectors 8 and 9 on tracks 0 through 19, which is bizarre.
    If your label matches this please talk to me so I can find out what I'm missing!
    You could look here, of course:
    https://winworldpc.com/product/ms-dos/50
    No way to know if the label matches, but comparing the contents of the other disks in the archive to your good ones should give some confidence.
    35,705
    Sorry, Mike. By that time, I was on 3.5" disks. I do have those, if it helps.
    Jun 2015
    Sioux Falls SD
    414
    I have MSDOS 5.0 on 360K disks. Mine say "SPRING" in the lower right where yours has "Microsoft". There are a few other differences in labels. Mine is a 5-disk set. I installed the set on my 5150 XT-IDE, so I know they work.
    Jun 2015
    Sioux Falls SD
    414
    MS-DOS 5 content.txt
    Here are the contents of all five disks
    Lafos - you are the winner! Yours match the four that I have perfectly.
    Jun 2015
    Sioux Falls SD
    414
    Hooray! Glad to help
    I have that same Spring set, still in the original box too. I was going to offer but I thought there's no way they will match the MS release exactly
