So, to sum up:
1) The original 720K disk works fine but not on the 5170.
2) The cracked 720K disk works fine on the 5170.
The conclusion is that the 5170 can't handle the copy protection.
Out of curiosity, can you try both the cracked and the original 720K disks on an XT or maybe a slow 286 clone?![]()
PM me if you're looking for 3½" or 5¼" floppy disks. EMail “” For everything else, Take Another Step
This is correct. Unfortunately my IBM 5160 does have a external 720k floppy drive BUT I have the problem as many people do with these drives. The drive reads, writes formats, copy BUT only a disk formatted on that drive. Any other floppy I insert is not readable. So in other works I cant test it. Funny thing if this original floppy disk works on my PII machine. So I gather its something with the 5170's hardware that affects the CP.
FWIW, I'm using a 1.44MB HD floppy on my 5160 as described here.
Alternatively, you could plug a standard 720K or 1.44M drive directly into the 5160's existing controller. Both would work however the 1.44M would only function with 720K disks.
I don't know about Sierra's copy protection, but some could take different code paths if they detect different kinds of machines.
What year were these disks produced? 3.5" 720k was considered kind of non-standard until the release of the IBM PS/2. If they were released before that, it could be your disks were intended for some specific PC clone.
What drive is in the system? There is even the slight possibility the compatibility is with the drive itself. For one example, if the software modifies the head step rate, it could crap itself when used in very early 720k drives. My money would still be on some glitch detecting timing, though.
If it were me, I might also try testing with a different BIOS, such as a more feature rich one from a later 286-clone. BIOS issues were a common source of compatiblity problems, although one would expect a genuine IBM to work.
It would be interesting to narrow down the issue.
I've just tested the 360k originals on my IBM 5170 and the same results. Complete computer lockup. Need to hard power off and on to get it going. These same disks run flawlessly on my IBM 5160, well the 360K disk that is, as in another post my external 720k drive is acting strangely.
It sure looks like it's a specific hardware compatibility issue. All your disks are good. Only one machine chokes on all of them. You're not very likely to determine exactly what that issue is -- unless you're willing to dedicate the rest of your natural life to it and even then it's iffy.![]()
haha. We need good old Peter Norton on the caseWell "one machine" happens to be an IBM 5170 8mhz. Guess they didn't sell to many of these. haha. Maybe something like SOFTiCE will help. But I think that only works on 386+ CPU's. Would be good to pause the program and debug it. In the end there is so much information I'm not sure how to document or archive all my findings. Google is getting too bloated. We need one area for Retro computing. Something like MobyGames but with technical sections where people could contribute copy protection schemes, strange errors on real hardware etc etc.
