Page 5 of 5 FirstFirst 12345
Results 41 to 43 of 43
Thread: AT&T PC6300 non-POST
  1. #41
    Mar 2013
    Chaffee, MO
    1,663
    In looking at the *.IMD files, and creating the *.RAW files, I see only one track of the floppy
    with the directory entries. The files appear to be missing.
    $imdu ATTP104.IMD ATTP104.RAW /B /E /D > ATTP104.txt
    IMageDisk Utility 1.18 / Mar 07 2012
    IMD 1.17: 06/11/2019 11:07:10
    File generated by the HxC Floppy Emulator software v2.9.5.1
    Assuming 1:1 for Binary output
     0/0 250 kbps DD  9x512
          1   2   3   4   5   6   7   8   9
          D   D   D00 D   D00 D   D00 D00 D00
     1/0 Mode value 130 out of range 0-5
    $hexedit ATTP104.RAW
    00000A00   52 45 41 44  20 20 20 20  4D 45 20 20  00 00 00 00  READ    ME  ....
    00000A10   00 00 00 00  00 00 5B 4F  D8 0E 02 00  7A 3D 00 00  ......[O....z=..
    00000A20   44 57 20 20  20 20 20 20  45 58 45 20  00 00 00 00  DW      EXE ....
    00000A30   00 00 0C 47  00 00 58 8E  64 0A 12 00  C0 56 01 00  ...G..X.d....V..
    00000A40   4D 4F 55 53  45 20 20 20  43 4F 4D 20  00 00 00 00  MOUSE   COM ....
    00000A50   00 00 00 00  00 00 2C 8B  D7 0E 68 00  70 1F 00 00  ......,...h.p...
    00000A60   4D 4F 55 53  45 20 20 20  44 4F 43 20  00 00 00 00  MOUSE   DOC ....
    00000A70   00 00 00 00  00 00 E5 89  D7 0E 70 00  81 68 00 00  ..........p..h..
    00000A80   53 45 54 4D  20 20 20 20  45 58 45 20  00 00 00 00  SETM    EXE ....
    00000A90   00 00 0C 47  00 00 29 7D  A1 0C 8B 00  00 59 01 00  ...G..)}.....Y..
    00000AA0   53 45 54 4D  4F 55 53 45  42 41 54 20  00 00 00 00  SETMOUSEBAT ....
    00000AB0   00 00 00 00  00 00 C4 69  2A 0D E2 00  03 02 00 00  .......i*.......
    00000AC0   53 45 54 4D  4F 55 53 45  44 41 54 20  00 00 00 00  SETMOUSEDAT ....
    00000AD0   00 00 00 00  00 00 FC 65  2A 0D E3 00  B6 39 00 00  .......e*....9..
    00000AE0   53 45 54 4D  4F 55 53 45  48 4C 50 20  00 00 00 00  SETMOUSEHLP ....
    00000AF0   00 00 00 00  00 00 97 4E  52 0A F2 00  77 1E 00 00  .......NR...w...
    00000B00   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
    00000B10   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
    00000B20   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
    00000B30   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
    00000B40   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ................
    Thanks.
    Larry
  2. #42
    Feb 2015
    Cleveland, OH, USA
    1,319
    I have resurrected a '486 machine and read four of the eight 5.25" AT&T distribution disks I have. I copied all of the files on these disks into folders (MOUSE, MPATCH, HELP, TUTOR) of their own, transferred them to this machine and zipped them into a 7ZIP file named ATTFILES.7z, which has been uploaded to the Incoming folder of Trixter's site by FTP. There is no imaging or streaming involved and I used XCOPY *.* /S /V so everything should be there.
    The other AT&T disks I have are STARTUP, OPERATNG, SUPLMENT and CUSTTEST, all of which I believe Trixter already has. But as long as I have the '486 out I can copy anything else anyone is looking for.
    This is the first machine I built for myself: A BIOSTAR VLB board with a CYRIX 486-DX2 proc, Paradise VGA card, 3 Ser. + 1 Par. ports, 1.4 and 1.2 Mb floppy drives, 3+ MB extended memory plus an Adaptec 1522 SCSI controller driving a Yamaha RW CD, a Bernoulli 150 and a 90 Mb ZIP disk. Compaq keyboard. DOS 6.2 & Win 3.11. Has to be nearly 30 years old but still runs, I'm pleased to say. A survivor (unlike my AT&Ts).
    -CH-
  3. #43
    6,988
    Many thanks! Moved to the public section of the FTP site.
    I'm concerned about the SCP images. If the Hx* tools can't translate the SCP images to raw or imagedisk properly, then are the SCP images useful? Worse, how can they be verified if nothing can read/interpret them?
    Edit: I answered my own question: The SCP images themselves appear to be invalid:
    File type : SCP_FLUX_STREAM - SCP Stream Loader
    Floppy interface mode : GENERIC_SHUGART_DD_FLOPPYMODE - Shugart Interface
    Number of Track : 80
    Number of Side : 1
    Total Size : 92160 Bytes, Number of sectors : 180
    The total size is wrong, most obviously. Also, the image should have been grabbed in double-step 40-track mode, since the sources were DSDD disks -- the extra tracks don't contain anything useful and just throw errors.
    I've removed them from the FTP site.
