Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: New project - the ROMulator, successor to the PETvet (RAM/ROM replacement plus debug)
    Apr 2011
    San Francisco, CA
    511
    Default New project - the ROMulator, successor to the PETvet (RAM/ROM replacement plus debug)
    Hi all,
    I'd like to introduce a project I've been working on for a couple of months now.
    Tentatively called the ROMulator, it's a RAM/ROM replacement board for the Commodore PET (and potentially other 6502 machines) as well as a debug interface which allows you to halt the 6502 CPU and read and write to/from the memory map. This is a direct replacement/successor to the PETvet, which was an earlier board of mine from a couple of years ago.
    It's implemented with a Lattice ICE40 UltraPlus FPGA, which implements the memory decode/enable logic as well as the full 64k memory map. Currently it supports up to 16 selectable memory maps with a dip switch. Portions of memory can be selected to be replacement RAM (read/write), replacement ROM (read-only), passthrough which bypasses the ROMulator and goes to the mainboard bus, or writethrough which echoes writes to the main bus and to the ROMulator. This is useful for capturing writes to screen memory which can be viewed in the debugger. Memory map properties are currently selectable at a granularity of 2048 bytes, but this can be an arbitrarily small number controlled by software.
    There is sufficient RAM available on the FPGA to not only replace the full memory map for the PET, but also do bank swapping controlled by writes to special addresses. Can enable some interesting software development.
    My goals with this project were to create a capable RAM/ROM replacement in as small a board as possible, at low cost. Also wanted the chance to learn about FPGA development, which was an interesting voyage. The ICE40 FPGA is the most expensive part at about $5, and I estimate the final price of the ROMulator to be in the $25 range.
    I'm getting in the latest rev of the board later this week, and if anyone is interested I will have a few early versions available, just let me know. If there's enough interest I plan to make these in larger volumes.
    Please let me know if you have any questions, thanks!
    - Mike
    Dec 2005
    Toronto ON Canada
    7,343
    Long time no see/hear, Mike.
    I definitely need one of these to add to my collection of PET tools; put me on the list.
    Coming up for the WoC?
    mike in TO.
    Oct 2017
    Kentucky USA
    115
    This is a great project potentially useful to a lot of owners of other systems. Hardly anyone makes them commercially anymore and they were expensive last time I looked. I recently made a special purpose 2716/2708 model for building/programming a 4004 instead of burning and learning. I dont know how to do FPGAs so I did it with a PIC and (now rare) dual-port RAM.
    May 2011
    Outer Mongolia
    2,290
    Good to see you around again.
    Project looks really neat. Is the FPGA on that carrier board or is it integrated on the lower circuit board? I assume the $5 price for the FPGA is just the bare die?
    Good to see you are still doing this stuff Mike. Sounds great.
    Tez
    My vintage collection: https://classic-computers.org.nz/collection/
    My vintage activities blog: https://www.classic-computers.org.nz/blog/
    Twitter: @classiccomputNZ ; YouTube Videos: (click here)
    Quote Originally Posted by gubbish View Post
    Hi all,
    - Mike
    We should talk about my dual-ported RAM FPGA solution that renders a VGA display straight from RAM by snooping on $8000-$8FFFF via a similarly socketed card. It might be a feature you'd want to add, though I haven't used that particular FPGA, so I don't know its capacity.
    Feb 2009
    Chattanooga, TN - USA
    892
    I'm in for one.
    Mar 2011
    Atlanta, GA, USA
    1,578
    I don't understand. The iCE40up5k is not a 5V nor 5V tolerant part. How are you doing level translation?
    "Good engineers keep thick authoritative books on their shelf. Not for their own reference, but to throw at people who ask stupid questions; hoping a small fragment of knowledge will osmotically transfer with each cranial impact." - Me
  9. #9
    Apr 2011
    San Francisco, CA
    511
    Thanks for the messages, all..
    Has been quite a while since I've been active in the hobby. Had a son a couple of years ago now, and between that and work, haven't had much time for vintage computer stuff recently. But recently I've dusted off the soldering iron and trying to get back into it.
    Would like to come to WoC, Mike, probably won't happen this year because of the little guy. But hopefully soon travel will be more of an option.
    The $5 price is just the ICE40 chip itself. It's on a little carrier board which brings the IO out to pin headers and has SPI flash and a couple of regulators and some resistors/caps.
    As eeguru mentioned, it is indeed not 5v or tolerant, so the board which has the 6502 CPU socket has a few 74LVC245s for level shifting. These are 5V tolerant, but output 3.3V logic for the ICE40.
    I'll take some better pictures and post a little demo video soon.
    I'd be very interested in trying the VGA output - the FPGA does have sufficient dual-port RAM to do it - 15KB I believe. As the design is now I believe there are 4 free IOs on the chip, so not enough for full color VGA but I think mono vga would be possible.
  10. #10
    Feb 2009
    Southern California, USA
    2,910
    gubbish,
    Put me down for one as all your designs are very interesting. Is the debug port going to be some kind of serial interface?
    -Dave
