Results 1 to 8 of 8
Thread: 3.5" SCSI HDD's - Preferably 1 or 2GB
    Jun 2018
    Los Angeles, CA
    236
    Default 3.5" SCSI HDD's - Preferably 1 or 2GB
    I just bought a PS/2 Model 95, and to my surprise all three of the hard drives (400MB, 85F0012) in it were dead. They make this strange clicking/thunking sound as if the head is banging against something. I guess it makes sense because they are all the same model, meaning they would have the same engineering defects. Anyway, I'm looking to replace them. I'm hoping for 1 or 2GB SCSI drives (can't go over 3.94GB), however I might be interested in lower capacity ones >= 400MB if you have multiple. They need to have the 50 pin connector though, not the 68 pin one.
    Feb 2017
    Guildford, U.K.
    292
    Ahh, the dreaded "ball bearing dropped onto a metal plate" sound.
    I'm too far away for cheap shipping. How about these?
    https://www.ebay.com/sch/i.html?_fro...+0662&_sacat=0
    FWIW, you only need to stick to the 3.94GB limit for the IML drive, with the "System Partition" on it, usually ID 6 with IBM SCSI adapters.
    There's also a utility to "fake out" a SCSI drive to report fewer LBAs than the maximum LLF-ed.
    http://ps-2.kev009.com/ohlandl/IBM_SCSI/scsifix.zip
    "IBM" HD summary, plus notes:
    http://ps-2.kev009.com/ohlandl/IBM_H...rd_Drives.html
    1,772
    SCSI is mostly backwards compatible, you can use adapters for 68 or 80 pin drives to work on the old 50 pin bus. I have several 68 to 50 pin and vice versa adapters that work fine on the piles of SCSI drives I have. I also have a couple of SCA-80 to 68 pin adapters which also work fine, they're just a bit kludgy due to the size of the adapter board.
    33,150
    It's also prudent to specify if you want 1/3 height or 1/2 height 3.5' SCSI drives. Some Seagate drives of that era came in half-height packages and may be too tall for your application.
    Feb 2011
    2,319
    10
    You might also consider a SCSI2SD board. 50pin connector. Many partitions. Just use a branded SD card.
    G4UGM
    Jun 2018
    Los Angeles, CA
    236
    I looked at SCSI2SD, but it's a bit too expensive for me. I found some good 1GB seagate SCSI drives for $20GB, + $10 68 pin to 50pin adapters, and I think I'm going to go with them.
    Jun 2003
    Cary, North Carolina
    340
    Quote Originally Posted by willmurray461 View Post
    I have several drives, probably 200MB=>1GB that are 50-pin internal SCSI whatever. I had a plan long ago that never panned out. I'm sure I can find them.
    Feb 2017
    Guildford, U.K.
    292
    Just FYI, I have an Auction thread here:
    http://www.vcfed.org/forum/showthrea...IBM-PS-2-etc-)
    the link at the bottom is quite useful, and I have numerous IBM ex-PS/2 drives of all capacities. Ask anything you like, I'm quite knowledgeable on the subject.
