Results 11 to 20 of 24
Thread: IBM EGA Card Memory Expansion Boards
    Mar 2015
    Colorado, USA
    106
    Quote Originally Posted by modem7 View Post
    I receive a HTTP 404 error for that link.
    Same here. Try it this way: here
    May 2006
    Melbourne, Australia
    6,478
    Quote Originally Posted by ab0tj View Post
    Got it.
    Where in the PDF, it shows "12.70", I measure 13 mm, so close enough there.
    However, the two holes in the IBM EGA card are 4 mm diameter.
    Apr 2010
    Albany, OR USA
    904
    Got it.
    12.7mm = 1/2 inch. So makes sense.
    Mar 2015
    Colorado, USA
    106
    Got it.
    Thanks for checking on this. Looks like the holes in the expansion card would need to be 4.8mm to support these standoffs, and they would fit in the 4mm holes of the EGA card. I'll keep looking but if I can't find standoffs that are 4mm on both ends, it looks like there's room in the expansion card design to enlarge the holes a bit.
  5. #15
    May 2006
    6,478
    The photos at [here] show how close the IBM Graphics Memory Expansion Card comes to the adjacent card in an IBM 5170.
    Clearly, that is why the IBM Graphics Memory Expansion Card has a protective sheet over its solder side.
    (The photo is not of my 5170's normal slot configuration. I normally leave an empty slot next to the IBM EGA card.)
  6. #16
    Mar 2015
    Colorado, USA
    106
    Default Good news and bad news...
    So the good news is... It works. I soldered it together and it required zero rework. Always nice when that happens.
    The bad news is there's some fitment issues. The holes for the standoffs had to be drilled out a bit... Not sure yet if that was a design problem or if I just hit the maximum size the board house can drill. Also I think I need a longer pin header to connect to the EGA card, because I have to bend the board in order to plug it in completely if using the standoffs.
    Overall not too bad for a prototype!
  7. #17
    Nice job on the board!
  8. #18
    outstanding!
  9. #19
    Jun 2006
    NC , USA
    1,103
    You might be able to just use a M-F header to extend the pins and get the proper board spacing.
  10. #20
    Mar 2015
    Colorado, USA
    106
    Quote Originally Posted by mikey99 View Post
    Good thinking. Though that may add too much length, really only need another 4mm or so
