Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: XT-IDE vs. SCSI on IBM XT/286
    Quote Originally Posted by 1ST1 View Post
    It's easy to get flash based IDE drive solution (CF with adapter), and that's much faster.
    No, it isn't
    Oct 2014
    near frankfurt/m, germany
    981
    This is XT-IDE with a CF card as drive 1 versus 20 MB MFM drive as drive 0.
    Yes I'm sure it is faster than a MFM drive, but it's not faster than a good SCSI. Or probably even a modern IDE drive for that matter.
    http://www.vcfed.org/forum/showthrea...ine&highlight=
    It is highly illogical to demand speed from vintage PCs Unless you are member of a rabbit secta
  5. #15
    May 2011
    Outer Mongolia
    1,775
    Quote Originally Posted by maxtherabbit View Post
    Unless you're running a highly unusual workload on your 286 access time is probably going to matter more than data transfer speed, and since flash solutions have nearly instantaneous random access times I would expect that a CF card would "feel" faster than even the most amazingly ridiculously fast SCSI drive, although realistically the difference probably wouldn't really be perceptable. Even a humble 8-bit XT-CF manages to benchmark at better than 500K per second in my 7.16mhz V-20 machine; 500Kps translates to being able to load essentially the largest possible DOS executable in one second; at that point would it matter much if it took half a second instead?
  6. #16
    Oct 2014
    981
    In that screenshot you can see 350 KB/s data transfer rate and a seek time of allmost ZERO. No cache, no mechanical SCSI drive can do that in an XT or 286 over the full capacity of the drive. I didn't expected the necessarity to explain that.
  7. #17
    Quote Originally Posted by Eudimorphodon View Post
    I know it's kind of buried in my thread, but the SCSI disk beat the CF card in both the "8K random, 70% read" and "sector random read" metrics of DISKTEST as well as sustained transfer metrics
  8. #18
    May 2011
    Outer Mongolia
    1,775
    In that screenshot you can see 1.4 MB/s data transfer rate and a seek time of ZERO.
    Maybe I'm misinterpreting the output, but it looks to me like it's 1.4MB/s over four seconds. (There's specifically a line that says "353.1KB/sec".) But the point is still clear from the "performance Index" output that this benchmark is *extremely* impressed by 1.5ms access time. As it should be.
    (Different benchmarks seem to differ a lot when it comes to data transfer rates. The 500+Kps I quoted was from Checkit. I don't think I've tried CORE on that machine.)
  9. #19
    Ya', nothing really compares to nitpicking over factors with fundamentally meaningless values.
  10. #20
    May 2011
    Outer Mongolia
    1,775
    The Quantum Atlas has an 8MB cache buffer with a sophisticated prefetch algorithm. According to this page:
    https://www.lo-tech.co.uk/wiki/DOS_Disk_Tester
    That test, unless otherwise instructed, uses a 4MB test file. It's very possible the entire file fits into the cache. In which case, sure, it's going to be faster, it's running from actual RAM.
