Results 1 to 5 of 5
Thread: MAc SE/8mhz - what games it can run ?
    Apr 2016
    Moscow, Russia
    111
    Default MAc SE/8mhz - what games it can run ?
    Hi, people ! I'm abought to buy an SE which is rare and expensive here) What good games it can run with 8mhz - like Prince of Persia or Grand Prix Circuit, TEst Drive or it's too slow even for it ?
    Maybe if I buy it I will use it for expos to show to "modern people" ...)
    Oct 2008
    Kamloops, BC, Canada
    6,000
    44
    Well the good news is that for the compact macs, the CPU speed doesn't matter. The SE will max out at 4mb of ram and I recommend system 6.0.4. You can run system 7 but you will be fighting to conserve ram.
    Your big limiting factor will be the black and white display. Most games and software will dither down but some games specifically want color.
    [Need something to waste time on? Click here to visit my YouTube channel CelGenStudios]
    [No time for videos? Click here to visit my Twitter feed @CelGenStudios]
    = Excellent space heater
    Edit: Here's a list I found.
    Prince of Persia
    Dark Castle
    Beyond Dark Castle
    Sim City
    A-Train
    Railroad Tycoon
    Crystal Quest
    Taskmaker
    Ultima II
    Ultima III
    Autoduel
    Bard's Tale
    Shufflepuck
    Lemmings
    Glider
    Arkanoid
    Battlechess
    Sargon
    Chessmaster
    Tetris
    Curse of the Azure Bonds
    Apr 2016
    Moscow, Russia
    111
    Quote Originally Posted by olePigeon View Post
    Prince of Persia
    Dark Castle
    Beyond Dark Castle
    Sim City
    A-Train
    Railroad Tycoon
    Crystal Quest
    Taskmaker
    Ultima II
    Ultima III
    Autoduel
    Bard's Tale
    Shufflepuck
    Lemmings
    Glider
    Arkanoid
    Battlechess
    Sargon
    Chessmaster
    Tetris
    thanks ! I think that's quite enought for a little mac monoblock from 1987)
    Aug 2006
    Chicagoland, Illinois, USA
    6,442
    Don't forget mobygames, which can help determine what can run as well: https://www.mobygames.com/attribute/...,0/p,74/so,1a/
    I'd say anything from 1990 or earlier should work.
    Offering a bounty for:
