Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 54
Thread: Adding NOPs
    There is a typo. in my post #7. I meant pages 1 and 2 not pages 2 and 3 as I have written.
    Page 3 will still affect the flip/flop though!
    It will be interesting to check how much RAM there is, there may only be 128 or 256 bytes - so that will make subroutines a bit tricky on a 6502... Although I am sure I have seen some subroutine examples in the manual. I will check...
    It only hooks up address line A0..A6, so the same 128 bytes are replicated through the memory map. As long as the stack pointer is initialized to $7F (or actually $FF would work, too), it will look like page 0 memory starting at $7F and working down will be used as the stack.
    3,553
    I had a bit of time waiting for a meeting to start today so I took another look at the schematics and concur with resman regarding the 'reflection' of the 128 bytes through memory.
    What it does mean is that you have to be careful about not using areas of the RAM that could be overwritten by the stack usage.
    I see that a later design of the OSI 300 has used used a larger RAM device. However, in this case, the stack should be contained to page 1 - but the limitations of page 1/2 to set/reset the 1-bit flip/flop will still apply and will be 'reflected' throughout the larger memory device.
    The use of the stack (i.e. subroutines) on page 1 whilst using the 1-bit latch may, therefore, cause you problems.
    One wonders why this address range was chosen? Was there another purpose?
    So the OSI 300 is pretty much the barest bones 6502 possible (with 1 bit I/O). It doesn't even have a ROM - you have to preload the reset vector into locations $7C and $7D (reflecting $FFFC and $FFFD), meaning you shouldn't use those values for anything else; like the stack in my example above. The flip flop set/reset is tied to A8 and A9, meaning that page 3 (or any page setting A8 and A9) would set and reset simultaneously. Including fetching the reset vector at $FFFC. Who will win? Why did they do this, besides being easy? Who knows.
    Quote Originally Posted by resman View Post
    I think with the design as shown, A9 and A10 would have allowed interrupts without issues.
    Without further qualifying the addresses of the flip flop's set & reset, any IRQ, NMI, or RST is going to drive both set & reset when the 6502 tries to fetch the vector from page $FF, setting A15..A8 high. I hope the flip flop is okay with that.
    Jan 2011
    Vancouver, BC
    4,853
    3
    So I finally got around to trying the program, and modified it for the required NOPs as thus (left column is address, right column is OP code/data:
    00 AD
    01 00
    02 02
    03 EA
    04 EA
    05 EA
    06 EA
    07 EA
    08 EA
    09 EA
    10 EA
    11 EA
    12 EA
    13 EA
    14 4C
    15 17
    16 00
    17 AD
    18 00
    19 01
    20 EA
    21 EA
    22 EA
    23 EA
    24 EA
    25 EA
    26 EA
    27 EA
    28 EA
    29 EA
    30 EA
    31 4C
    32 00
    33 00
    I did not get any sound, although the program (I think) seemed to run okay.
    I may be misunderstanding how to hook things up. The manual says to connect the 'output latch' to the aux input of a standard stereo, being careful to attach the ground first. On this diagram you can see two output pins:
    I tried connecting the input to the stereo to both, with the 'shield' connected to ground.. and got zippo running my program. Did I goof somewhere?
    Jan 2011
    Vancouver, BC
    4,853
    3
    Another possibility I suppose is that the stereo I'm using is not suited.. it's an early 90s Realistic unit.. think it might be digital. I do have a circa 1973 Sony deck I could try?
    If you put your finger on the audio input without having your self grounded, you should get a buzzing sound. That checks that the audio is working.
    If the sound is in the range calculated you should hear it. What is your cycle time?
    It's going to be a little difficult to debug without any real insight into the operation of the CPU, but a few things to try:
    Did you initialize the reset vector to $0000?
    When it comes out of reset, does the binary representation of $EA (11101010) sort-of show up on the data LEDs?
    Do you have any kind of digital probe or oscilloscope? Looking at the input and outputs of the flip-flop would be a tell-tale sign that things are signaling.
    If the clock speed is ~1 MHz, the tone from that code will be pretty high. Our hearing isn't what is used to be. Just sayin'
