Results 21 to 30 of 34
Thread: AT&T PC6300 Storage Configuration
  1. #21
    Oct 2014
    near frankfurt/m, germany
    981
    Seconded. Even though I'm the current owner of the "cut a hole in the front panel" 6300, I don't recommend it.
    This was quite common for M24 users in old times. Some cut out the hole for floppy drive destroing Ettore Sottsass's design. Others were clever and put a 3.5 inch harddrive vertically besides the floppy bays and put 3,5 floppy where it should be.
  2. #22
    Aug 2017
    New York, Rome, London
    108
    Not sure if this is/isn't a good thread to mention this in, but I've had reliability issues with a 720K drive in my 6300. It appears to work fine after the typical config.sys "DRIVPARM=/d:1 /f:2 /t:80" line, but I have random silent bit errors that go undetected by DOS even with VERIFY=ON. So, I only use the 720k drive in my 6300 to read .zip files, where it will be obvious if it bit has flipped (pkunzip will complain). I've never been able to nail down what the trouble is.
    Is there some software that can be run to thoroughly test the working of the 720k drive? Does the original CUSTOMER.EXE work with a 720k, ie can it run the floppy drive test for it? (I can try later tonight with mine...)
  3. #23
    33,093
    Given that all fields (address and data) are generated and checked by the FDC hardware with 16-bit CRCs, a completely "silent" error points to something further up the chain from the FDC. Could be noise on the bus...
  4. #24
    Oct 2014
    981
    Chuck points in the right direction. When M24 was made, it still was common that one had to set/remove terminator resitor arrays on the drives, depending which one is the 1st or 2nd drive, or alone. Later, when 3.5 inch became popular, this was no more common. This change bases on the floppy controller type (like M24) and the used floppy drives. So solution could be trying 3,5 and 5,25 drive as 1st and 2nd drive on the cable, and remove/install the terminator resistor.
  5. #25
    6,217
    I can give that a shot, although my options might be limited as I want to keep the 5.25" the 1st drive for hopefully obvious reasons.
    It's not a dealbreaker -- I usually use that system with a NIC and transfer stuff over FTP anyway -- but I'll poke around the next time I'm inside.
  6. #26
    Aug 2017
    108
    Ok I tried the customer.exe test and it worked fine, all tests passed on the 720k drive. I also remembered one thing: I donít use DRIVPARM! I just boot plain old MS DOS 6.22, on the boot disk that I use I donít even have a config.sys file! It still works though...
  7. #27
    33,093
    Shouldn't matter until it's time to FORMAT a disk.
  8. #28
    Aug 2017
    108
    I did that too just now - twice actually - once to prepare the blank disk for the customer.exe test (it requires a formatted disk), and once after the test to make the disk usable again (the write tests do not leave disks in a usable state). I am a bit puzzled.
  9. #29
    33,093
    That's why you need DRIVPARM--it tells FORMAT what the drive really is.
    You could also try FORMAT x: /T:80 /N:9 /U, but without DRIVPARM you'll probably get "Format not supported" or some such error.
    For reading and simple writing, the BPB in the boot sector is used.
  10. #30
    There's also SETBPB35:
    ftp://ftp.oldskool.org/pub/tvdog/tan...isc/setbpb.zip
    This program will set the device characteristics for the A or the B diskette drive to indicate that the drive is a 720K drive instead of a 360K drive. The only command line parameter is the drive letter (A or B).
    For example, to indicate that your B drive is a 720K 3.5" diskette drive:
    SETBPB35 B
