Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: HP Colorado T1000 vs Connor Jumbo 250/FC-20 Controler
    33,153
    18
    Exactly--the caution here is not to go overboard. You can get DDS4 and DDS5 tape drives that are fed with differential ultra640 SCSI, which would be expensive overkill--your P3's disk could never keep up with the tape drive. A DLT IV capable drive is about as far as you'd want to go in the DLT area with a P3 box.
    I didn't touch on LTO--for a PC, I think it'd be expensive overkill again.
    Jun 2012
    Livermore, CA
    353
    Thanks again everyone, all the input is very much appreciated!
    DLT IV capable drive on ebay is over $500. That is a bit to much past my hobby budget.
    Other possible suggestions
    Atari Falcon030, Atari MSTE, Atari PS3000, STACY 4, 4160STE-CosmosEX, Atari PC1, 400/800/1200XL,800XL,800XE,130XE, XEGS, Apple IIGS, TRS-80 4P, TI 99/4A, Co-Co 3, Amiga 500, C64/128D
    33,153
    18
    There are plenty of DDS/DAT drives on eBay for cheap.
    Here's a seller with NOS HP DLT/VS 80 SCSI drives for not a lot. (They're UW SCSI-2, so should not be a problem). And they're half-height SCSI. Documentation is on the web.
    80GB per tape is a lot more than that T1000 can do.
    Jun 2012
    Livermore, CA
    353
    Thanks Chuck, I was looking using the wrong terms.
    I have a Jazz drive with a iomega scsi card. I would need a 2 drive cable with a terminator to use this card? Or a different card/cable?
  5. #15
    Feb 2017
    Guildford, U.K.
    292
    It'll depend how you build the external drive SCSI bus. You just have to enable termination on the last drive, either by drive jumpers/switches, or via an external terminator pack (of the correct connector type and Active/Passive type) on the drive's external 2nd connector.
  6. #16
    33,153
    18
    Note that the drive I pointed to is ultrawide SCSI2; If you've got the Jaz Jet Ultrawide (68 pin connector), you're good. The 50 pin connector is a narrow SCSI. You can use a narrow SCSI drive with a UW controller, but not always the reverse.
    Check the user manual if the latter condition obtains.
  7. #17
    Feb 2017
    Guildford, U.K.
    292
    If it's the Jaz Jet PCI Ultra SCSI-2 adapter, then you'll need an HD50-HD50 cable to the Jaz drive and an HD50-HD68 converter cable (or HD50F to HD68M adapter) to the DLT drive, and need to ensure it has an ID <= 6. Then you'll need to terminate the bus at the DLT drive.
