Results 1 to 3 of 3
Thread: Rosewill Hercules 1600S power supply
    Jan 2005
    1,527
    Default Rosewill Hercules 1600S power supply
    https://www.newegg.com/p/N82E1681718...82E16817182251
    I have less then 100$ total in this thing. How would you test it?
    Old reviews claim all Japanese capacitors. Is that likely 6-7 years after it's inception (and hundreds of dollars less)?
    For the sake of argument what would it cost to recap the unit with Japanese caps?
    Mar 2009
    Dublin, CA USA
    2,824
    Rosewill is known for making really good PSUs, so if the one you have is old, and powers up, then you are more than likely A-OK and can trust it.
    I think the real question is why you need 1600 watts of power for your rig. Few people need more than 600W
    Jan 2005
    1,527
    It's not old, I just bought it. I was wondering if they still used Japanese caps as they did in the early models. No mention in the description. I didn't even peruse the supplied documentation. Back in 2012-2013 iinm they were 400$.
    I just get crazy with certain accoutrements. My only rig currently is an old dual socket 771. It has an 850 watt Xion p/s currently that so far is doing fine. I don't care if that mobo gets fried. I have about 80$ total into it. And it served to get me up to speed on computer building, as I hadn't done it in ~17 years. Learned quite a bit, still much to be learned of course. I'll put the Herc inside the box and hope I don't go up in smoke. I know at least that I will be feeling all 1600 watts once I throw the switch.
