Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Kaypro II floppy mod ?
    Mar 2013
    Chaffee, MO
    1,343
    CH,
    The Schematic is done and in easyeda. The PCB Layout is done and in easyeda. I double checked
    the Pinouts with with the "F" Version Floppy Pinouts and found the Robie and 4-84 series also uses
    Pin 4 and Pin 34, which none of the earlier versions used. So, I updated the .SCH and .PCB files
    accordingly.
    Next, I need to locate my Photo's and compare the PCB Layout to my Original Micro Cornucopia
    Circuit Board to double check everything. Next would be the BOM, to locate the additional parts
    to assemble the Board.
    I guess I need to make a new posting to see what the interest would be for PCB's.
    Thanks.
    Larry
    Feb 2015
    Cleveland, OH, USA
    1,044
    Thanks. If there is enough interest to make it worth your while, count me in.
    -CH-
    Mar 2013
    Chaffee, MO
    1,343
    I'm not planning on retiring again after making 20 to 40 or more PCB's.
    It's more to support the Older CP/M Machines and keep them rolling with
    GOTEK's and the like. If I break even it's a good thing.
    Larry
