Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Lightweight TSR DOS Text Editor; Your Favorite?
  1. #21
    Feb 2015
    Cleveland, OH, USA
    1,035
    Which DOS program do you prefer to use to effect these types of modifications?
    Anybody else with a preferred program for this procedure, please chime in.
    DEBUG is handy, convenient and suitable for something so simple as this; even a noob like me can use it...
    -CH-
  2. #22
    Other than G=C800:5 and its ilk I know nothing about DEBUG.
    Got any tips and pointers to share to get me going in the right direction?
  3. #23
    ..Anybody else with a preferred program for this procedure, please chime in.
    A Hex editor, Windows or DOS, I use HxD in Windows and HIEW in DOS
  4. #24
    Feb 2015
    Cleveland, OH, USA
    1,035
    DEBUG allows you to view, execute and change programs and runs under DOS; I believe it is included, for those who may not know, with many DOS versions up to 7. (I don't know about < 3.11)
    Someone who goes by the sobriquet "Starman" (Daniel B. Sedory) has posted a useful tutorial: https://thestarman.pcministry.com/as...g/debug2.htm#D
    DEBUG Path\UFN.XTN loads a file** into memory and presents you with a "-" prompt. From there you can (D)ump code for viewing, G(o) - execute, either to a breakpoint or to completion, (E)nter - change one byte instruction or (A)ssemble many instructions, (U)nassemble lines of code, view the contents of the (R)egisters as of the current line of code or (W)rite all or a portion of memory to disk. Writing to disk is not recommended unless you first specify a name for the block you are writing with the (N)ame command; given a path and name and DEBUG will place the file in the appropriate place in the file system. If you Write without thinking who knows what will happen to your disk.
    Since SIMON is a COM program and COM programs are by definition <= one Code Segment (64k) there is only one CS value in the register to deal with. DEBUG only knows abut hexadecimal values, so there is no need to differentiate values, except of course for strings: -e 7791 90 changes the first byte of the two-byte instruction b44ccd21 mentioned in his listing (jae loc-779A). Note there is no leading zero or trailing H on hex value 90, which is substituting a NO OP for the jump. Another 90 at the next location, 7792, and the change is complete. Use the N command to specify a path and name for the new file and W, write it to disk. Q is for "quit".
    -CH-
    **File does not have to be a COM or EXE: You can submit a text file containing valid machine instructions as a source, which you can then save as a COM file. Or the file doesn't have to be code at all; DEBUG will list (as hex) or disassemble (to mnemonics) any source, up to its limits. See Van Wolverton's Supercharging MS-DOS for examples.
  5. #25
    Feb 2015
    Cleveland, OH, USA
    1,035
    Quote Originally Posted by Malc View Post
    There is a "better" DEBUG which is part of the FREE DOS project as well. Don't know HIEW. Initially I considered MASM and TurboDebugger but it was like swatting flies with a Howitzer.
    HxD or Hex Editor NEO are favored for Windows.
    By the way, thanks for all your help and Merry Christmas!
    -CH-
  6. #26
    Charlie, thanks for your detailed help and guidance. I know it's right on because I actually figured it out about 30 minutes before you posted your dissertation. Gee, and it only took me ~ 18 hours -- minus a few hours while I slept. But, thanks, again as it is really helpful and I'll definitely look at the FREE DOS version as well.
    Merry Christmas
  7. #27
    Feb 2015
    Cleveland, OH, USA
    1,035
    ... you posted your dissertation.
    Yah, my wife's eyes kinda glaze over when I try to explain something to her...
    -CH-
    And Merry Christmas to you as well.
  8. #28
    Feb 2015
    Cleveland, OH, USA
    1,035
    Quote Originally Posted by clh333 View Post
    ... (E)nter - change one byte instruction or ...
    ... changes the first byte of the two-byte instruction...
    The proper term, of course, is "word", not "byte". Somebody, who should know better, must have been thinking about something else to make a mistake like that. Mea culpa.
    -CH-
  9. #29
    -CH-
    My DEBUG mojo is virtually non existent, Shouldn't be considering the years i've been playing with old computers, I started messing around with the likes of HIEW, OllyDbg, HxD, IDA Pro etc or i try and throw something together in C but my skills in C are not up to much either.
  10. #30
    Mar 2017
    New Jersey, USA
    551
    On the PC, the tools I generally used for this kind of thing in the DOS days were Turbo Debugger to identify what to patch (and to test patches), and Norton Disk Editor to actually apply (i.e. save) the patch once it was finalized. This of course required a 386, but it was a lot easier to work with than Debug. In particular this method worked well for patching large .EXE files, while I only felt comfortable using Debug for .COM files. I did not do this very often so I had no need to invest in more sophisticated tools.
    Many years later I invested in a copy of IDA Pro during a period where I was doing a lot of reverse-engineering of C++ code, but that was mostly for identifying function entry points rather than actually patching anything. I think I only ever used IDA Pro for static analysis of EXE files on disk (unlike the dynamic analysis of running programs I did with Turbo Debugger).
