Results 1 to 10 of 10
Thread: What is this? A Commodore cable?
    Nov 2019
    New Jersey, USA
    17
    Default What is this? A Commodore cable?
    Could anyone advise as to what this cable is?
    A parallel printer adapter for the C64 or VIC-20.
    Nov 2019
    New Jersey, USA
    17
    Quote Originally Posted by vwestlife View Post
    Ah, I knew it looked familiar... now it makes sense. Thank you!
    I'm assuming this is homemade? Were these actually sold?
    Looks like a commercially made one with the label fallen off.
    Apr 2018
    Los Angeles, CA
    788
    Of course, back then, the difference between 'commercial' and 'homemade' weren't far removed. I have one that's even jankier than this, but at least the 'manufacturer' printed the info directly onto the case.
    -- Brian
    Question: could you open the case so we could have a look inside, please? With these printer cartridges I'm always interested in what hardware they use.
    I had some of these cartridges and IIRC they used the +5V supplied by the printer. Funny to see one where you have to tap it from the cassette port.
    www.baltissen.org
    Apr 2018
    Los Angeles, CA
    788
    So i have two myself, one is broken but was a grappler type... both of them pull power from the cassette port which was common for commodore accessories. Super sketchy, but you could get away with things like that back then, and power supplies were much more expensive to make, so likely just a way to keep costs down.
    -- Brian
    Nov 2019
    New Jersey, USA
    17
    Here you go!
    Oct 2018
    Northern Idaho
    26
    It's a Xetex Super Graphix Jr case without the cutout for the dip switches. I wonder if another company made it and put their own sticker on it.
    Jan 2019
    St. Paul, MN
    118
    That's how *all* of them were powered, at least initially. The original Centronics 36-pin spec doesnt include a +5VDC line for power. I'm not sure who was first, but at some later date manufacturers started adding the +5V line and it became sort of a de-facto standard as others followed suit.
    All of the popular CardCo interfaces used cassette port power. Some designs had the connector, but featured a board jumper to select printer cable or cassette power.
    Auf wiedersehen, schweinhund!
