Results 1 to 6 of 6
Thread: Forum is crashin on Windows98
  1. Default Forum is crashin on Windows98
    I have tried to use the forum on Windows 98 with the last Firefox available for Windows 98. It loads nice within a few seconds, but after an additional second, firefox crashes. The bug happens all the time. Probably its due to a javascript file thats embedded into the forum.
    Apr 2015
    Austin, Texas
    1,860
    It could be the social media scripts (google and facebook are used on this forum) that are loaded in the background, which is a common issue on older browsers.
    You can try to block the connection to the social media sites in the Windows HOSTS file in %windir%
    https://en.wikipedia.org/wiki/Hosts_(file)
    Just redirect the sites to 127.0.0.1
    An example would be
    127.0.0.1 connect.facebook.net
    127.0.0.1 google-analytics.com
    Another alternative is to try the mobile site:
    http://www.vcfed.org/forum/showthrea...ws98&styleid=3
    You can switch via the style dropdown on the bottom left of the page.
  3. Default
    good idea, i will try blocking facebook and google in my router, i dont use these services aniway.
    What version of firefox are you using?
  5. Default
    Quote Originally Posted by Robbbert View Post
    i am not sure, but it was probably 2.0.0.1x or 2.0.0.20
    Apr 2015
    Austin, Texas
    1,860
    The FF 2.x branch was the last to support Windows 98SE. You can get 12 or 15 working by using KernelEX, but it is slow and unstable.
