Results 1 to 10 of 28
Thread: New old stock Cardinal CP600 terminal units circa 1988
    Default New old stock Cardinal CP600 terminal units circa 1988
    Bought one as a prop for a project I am doing (will be using via serial cable). The seller has none listed so I contacted him directly via an Ebay msg and he says he has access to 40-50 new old stock units. Sold one to me on demand via Ebay. Very nice guy. I negotiated a slightly lower BIN price.
    More info: https://deskthority.net/wiki/Cardinal_CP600
    Completed listing (he will be listing them one by one):
    https://www.ebay.com/itm/VTG-Termina...rdt=true&rt=nc
    He stated to me you can contact him via an Ebay msg directly if you are interested in one, but he wont be able to start listing them on a regular basis until mid January.
    Sep 2006
    Silicon Valley
    2,147
    has anyone opened one up yet, or dumped the firmware?
    The one I just ordered is on the way. If you like, I can try and help with this, just PM me.
    Sep 2003
    Ohio/USA
    7,803
    They look kind of cool, what kind of monitor do you connect to them (monochrome, CGA?)
    From the Ebay photo the case cut-out holes in the back for analog RGB and TV look empty and only composite seems to be populated. I am wondering if the PCB already has circuitry for those other video hookups. Know absolutely nothing about these. I believe they were used for point-of-sale roles since they have a supposed card swipe on the side, but with that 25-pin serial in back I am guessing they can be used as a dumb terminal with pretty much anything. Find out more when I get it I suppose.
    Dec 2010
    Seattle, WA
    1,896
    Looks similar to the RCA VP4801. My guess is that the Cardinal CP600 also has an RCA 1802 on the inside. I haven't dumped the firmware of the VP4801 yet. I could do so if someone wants that.
    From my notes on the VP4801 PCB:
    U051    - LM340T12      3-Terminal Positive Regulators, 12V
    U052    - LM320T12      3-Terminal Negative Regulators, -12V
    U053    - LM340T5       3-Terminal Positive Regulators, 5V
    U054    - RC4558N       Dual General-Purpose Operational Amplifier
    U055    - CA3083        General Purpose High Current NPN Transistor Array
    U101    - CDP1802ACE
    U102    - CD40106BE     Hex Schmitt Trigger
    U103    - CDP1866CE     4-Bit Latch and Decoder
    U104    - CDP1867CE     4-Bit Latch and Decoder
    U105    - CD74HC138E
    U106    - F4013BPC      Dual D-Type Flip-Flop
    U107    - F4069UBPC     Hex Inverter
    U151    - SCN2671A      Programmable Keyboard and Communcation Controller (PKCC)
    U152    - CD4051BE      Single 8-Channel Analog Multiplexer/Demultiplexer
    U153    - CD4051BE      Single 8-Channel Analog Multiplexer/Demultiplexer
    U201    - CDP1852CE     Byte-Wide Input/Output Port
    U202    - CDP1852CE     Byte-Wide Input/Output Port
    U203    - CD4058BE
    U204    - CD4073BE
    U205    - CD4011BE
    U251    - TMS99532NL    Frequency-Shift-Keyed Modem
    U252    - RC4558N       Dual General-Purpose Operational Amplifier
    U253    - CD4015BE      Dual 4-Bit Static Shift Register
    U254    - CD22859E      Dual-Tone Multifrequency Tone Generator
    U255    - RC4558N       Dual General-Purpose Operational Amplifier
    U256    - CD4053BE      Triple 2-Channel Analog Multiplexer/Demultiplexer
    U257    - H11AA1        Optocoupler, Phototransistor Output, AC Input
    U351    - CDP1852CD     Byte-Wide Input/Output Port
    U352    - CDP1852CD     Byte-Wide Input/Output Port
    U353    - CDP1852CD     Byte-Wide Input/Output Port
    U354    - unpopulated
    U401    - CDM6116AE3    2KB Static RAM
    U451    - CDP1852CD     Byte-Wide Input/Output Port
    U452    - CA3083        General Purpose High Current NPN Transistor Array
    U453    - CA3083        General Purpose High Current NPN Transistor Array
    U501    - SCN2672B      Programmable Video Timing Controller (PVTC)
    U502    - CRT8002B      CRT Video Display Attributes Controller Video Generator (VDAC)
    U503    - SN74LS75N
    U504    - SN74LS161AN   Synchronous 4-Bit Binary Counters
    U505    - SN74LS00N
    U507    - SN74LS04N
    U508    - SN74LS123N
    U509    - DM74LS74AN
    U701    - CDM6116AE3    2KB Static RAM
    U702    - CDM6116AE3    2KB Static RAM
    U703    - AM2764
    U704    - AM2764
    U705    - unpopulated
    U706    - CD4556BE      CMOS Dual Binary to 1 of 4 Decoder/Demultiplexers
    U801    - SN74LS00N
    U803    - CD4011BE      Quad 2-Input NAND Gate
    U806    - DM74LS74AN
    U807    - SN74LS00N
    U901    - MC1489P
    U902    - MC1488P
    U903    - CD4053BE      Triple 2-Channel Analog Multiplexer/Demultiplexer
    Huh, interesting. I'll take a photo of the PCB when it comes in. According to that deskthority page above I'll have to be careful as it seems those Cardinal units are held together by plastic clips. Your RCA unit seems like a better build quality.
    Sep 2006
    Silicon Valley
    2,147
    would be nice to get the firmware dumped, glen
    to add to MAME
    So the unit came in. Will get the docs scanned and uploaded to -0 soon.
    Cardinal CP600 Wide 200Kish.jpgCardinal CP600 Close 200Kish.jpgCardinal CP600 Rear Left 200Kish.jpgCardinal CP600 Rear Middle 200Kish.jpgCardinal CP600 Rear Right 200Kish.jpgCardinal CP600 PCB Left 200Kish.jpgCardinal CP600 PCB Right 200Kish.jpg
    Best I can do for now as far as photos. They are definitely new old stock. The plastic clips were very easy to undo for the lid removal. Nice terminal unit for the money.
