Results 1 to 10 of 13
Thread: Has there ever been 68000-bit processors?
    Default Has there ever been 68000-bit processors?
    I am that old Macs have 68k processors, but there is no such thing as 68000-bit, the current Macs are 64-bit! What am I getting wrong here?
    3,853
    The 68k refers to a Motorola part number. 64 bits refers to the native data bus width of the processor.
    The 68000 CPU was a Motorola 16 bit processor with an external 16 bit data bus. The 68008 CPU was a Motorola 16 bit processor with an external 8 bit data bus. Internal logic read two sequential 8 bit data bytes to form a 16 bit word internally.
    A modern iMac contains a 64 bit Intel processor.
    Hope that clears up the confusion?
    Sep 2006
    Silicon Valley
    2,275
    is the 68020 a 16 bit processor?
    Outer Mongolia
    2,396
    I'm pretty sure people have come to blows (beer bottles smashed on the bar, the whole enchilada) over whether or not the 68000 should be called a 16 or 32 bit processor, but I think the 32-bit-ness is pretty unequivocal in the case of the 68020.
    3,853
    Yes...
    Is a Zilog Z80 an 8 or 16 bit machine? It has 8 bit registers internally, but they can be ‘joined together’ to form 16 bit register pairs. To further confuse things, you can perform 16-bit arithmetic on some of the register pairs. I would still call the Z80 an 8-bit processor however.
    Churches have been built on less...
    34,368
    I generally go by the width of the ALU. Not always, however. There are some serial ALU minis and microprocessors; it just wouldn't be right to call them "one bit".
    Dec 2010
    Seattle, WA
    2,020
    Don't forget the 65536-bit CM-1
    Yes, it does!
    Jun 2011
    Portsmouth, England
    266
    I read once that the Z80 has a 4 bit ALU so maybe it is a 4 bit processor, maybe this explains why the 6502 is sometimes faster.
    3,853
    Let’s not ignite that flame war shall we !
