Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: IBM Academic System 6152?
    Sep 2016
    Shrewsbury, MA
    1,147
    Quote Originally Posted by bear View Post
    I can send you a copy of the 6152 reference disk, but (assuming the disks don't still have AOS) if you want to install AOS and use it as an Academic System, you need another RT already running AOS to network install from. The 6152 install doesn't support tape.
    There's nothing special about the Model 60 part, apart from the stickers which would identify it as a 6152 rather than an 8560.
    Please invest some energy into saving the ESDI drives. If the AOS install is already present on them, there are some bits that are still lost (i.e. the original X11R3 binaries, which were built from source with unreleased patches from IBM, and a couple files for the OS/2 version of the host app) that it would be nice to see if they might be recovered from your system. Let me know if you need help with that.
    That would be great if you could send me the reference disk. I did pull the drives and esdi controller, and I'll be dropping the parts off with someone I know who has a model 60 and is much more familiar with risc hardware than I am so he can hopefully make sure everything works and archive the files on the hard drives
    Thank God, it looks to support SCSI.
    240Mb of fixed disk storage can be provided on the RT PC
    models above with their 70Mb hard disk and 200Mb IBM 9332 Direct
    Access Storage Device(s) attached via a SCSI Adapter (#7000). See
    IBM Product Announcement 186-174, dated September 18, 1986.
    o Communication Adapter
    http://ps-2.kev009.com/ohlandl/6152/Crossbow.html
    A model 80 helps as the 286 cpu becomes a bottleneck.
    Angry Index of AOS Fixes
    Feb 2017
    Guildford, U.K.
    294
    anyone know an alternate site for ftp://ftp.ps-2.org/ibm-rt/ which is now 404
    OK, herculean efforts by Pete Backhouse overnight and his site is back as:
    http://ps2.purpletartan.com
    There should be a subdirectory called ../old-ftp/ thereunder.
    WBST was able to contact Pete. Did someone have a copy of the refdisk? Though it probably is an 8560 with the Crossbow ADF, who knows? I'd very much like a copy to hang on the web...
    http://ps-2.kev009.com/ohlandl/6152/6152.html
    33F6215 Academic System 6152 Quick Reference Jan88
    AOS 4.3 Program Files
    AOS 4.3 Documentation
    Crossbow RISC Adapter
    Feb 2017
    Guildford, U.K.
    294
    Quote Originally Posted by ardent-blue View Post
    Thanks for the credit, Louis.
    Sep 2016
    Shrewsbury, MA
    1,147
    I managed to score an IBM Academic System front panel on ebay for pretty cheap, now all I need to build it up is a model 60 or 80 to put the card amd original drives in
