Results 1 to 2 of 2
Thread: Apple IIc monitor repair
    Default Apple IIc monitor repair
    Working on a IIc monochrome monitor. I've got power after replacing fuse. The CRT neck has a dim glow
    but no video. At turn off it lights with the usual horizontal bands that quickly fade to black.
    I have looked but have not found web information on the repair of these displays.
    Any help will be greatly appreciated..
    Oct 2008
    Kamloops, BC, Canada
    5,888
    44
    Sounds like you got both power to the neck and high voltage with a raster, so that's good.
    Verify the solder joints where the video connector attaches to the board are not funky.
