Results 11 to 20 of 28
Thread: RAM chips in my Tandy 1000 TX
    Interesting discussion, but I think upgrading all the ram to 120ns certainly can't hurt. I may just give it a try and we are not talking a huge amount of money. I think about $30 would cover everything.
    Outer Mongolia
    1,931
    Just remember the cheap wipe sockets on the motherboard are only good for so many insertion cycles.
    (Again, unless you're actually seeing some bad behavior it's not going to do anything.)
    I am seeing some unusual behavior and that is why I am going to replace all the memory. The system has not been 100% stable. I think it's worth a shot at this point.
    Apr 2018
    Los Angeles, CA
    794
    Just remember, the OP's TX already has a 286 so a V20 isn't really on the table.
    I guess I didn't catch that (don't have a TX myself)... good point.
    Looks like we're done here anyway.
    -- Brian
    I swapped all the 150ns memory for 120ns. The instability issues I was having are now gone. Total cost was around $30 for 16 120ns 256kx1 and 4 64kx4 chips. Well worth the time and effort
    Sep 2008
    SE MI
    4,415
    6
    Quote Originally Posted by jasa1063 View Post
    Well, slap Leisure Suit Larry in that thing and see how it goes.
    Outer Mongolia
    1,931
    Might be worth running a few loops of the "hard" version of the memory test in Checkit! 3 to make sure all's well.
    I ran the extensive memory test with Checkit 3 a few times after I installed the ram. All tests passed!
    Outer Mongolia
    1,931
    Excellent!
    I still doubt the speed of the old ram *per se* was the problem, it was probably fine when the machine was new. But getting old happens to all of us; I've run into bad RAM a few times over the years. (Most recently on an Apple IIgs of about the same vintage as your TX.)
    When I got the computer off of eBay and opened it up, the metal frame was bent and warped in a few places. I was able to straighten everything out, but obviously it has sustained some damage sometime during it's life. Some of the RAM chips were probably on the receiving end of that damage.
