Results 1 to 6 of 6
Thread: Compaq Portable opening
    Default Compaq Portable opening
    Hello,
    I have troubles with opening my Compaq. Is there some trick? I watched some videos on Youtube and I dint see any problem with that.
    I can open it only like this (picture) nothing more, I tried as hell and nothing. This is bottom plate, upper is already opened.
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155: IBM PC Expansion Unit 5161:
    WANTED!: IBM 5175 monitor, IBM 5145 monitor, IBM PC/XT/AT rear screws, Intel INBOARD 386AT card, IBM 5140 keyboard, very early IBM PC (S/N: under 5000)
    My IBM PC hardware collection
    PM me if you're looking for 3½" or 5¼" floppy disks. EMail “ ” For everything else, Take Another Step
    well, nothing helpful.
    It won’t open any further than that? Very odd. You have all of the tabs undone, so it should come off. I’d suggest shining a flashlight in there and see if you can spot any that might be holding it.
    Compaq - “It simply works better”
    Try almost closing it, pulling it outward (toward the handle) and then open, then inward (toward the handle) and then open. Or try jiggling it left and right.
    It looks like something is sticking at the monitor-side of the panel.
    Current favorites: IBM 5160 (EGA+Hercules+PGC, 4 floppies, XT-IDE), DCC D-116 (Nova 1200 clone), ASR 33 Teletype (now FULLY armed and operational! Mostly.)
    Wishlist: IBM 5161 (expansion chassis), IBM 5175 (monitor for PGC), 7 or 9 track magtape transport, Data General Nova software, and the meaning of life.
    Quote Originally Posted by Nevets01 View Post
    Not helped at all...
    Its looks like there is some plastic spot, which is not moving with whole panel, but i cant identify what can it be. This spot is not accessible from inside so if is there some screw, I cant move with it.
